TOS 6.0.460 (X86) Beta is Released for Update
abs1ck
Re: TOS 6.0.460 (X86) Beta is Released for Update
Post by abs1ck »
I couldn't update via the web interface, but I managed to do it manually. The fans have not turned off completely yet, I hope they have fixed this
UPS Support not enabled after upddate
Basically looks like a lot of options have to re-checked.
Will see how things are after overnight shutdown.
Naill
Christmas Island
Post by Naill »
Unable to CPU limit a docker container. Try to set a cpu limit
docker run -it --rm --cpus 1 nginx
docker: Error response from daemon: NanoCPUs can not be set, as your kernel does not support CPU CFS scheduler or the cgroup is not mounted.
jpeckinp
Post by jpeckinp »
Gremlin wrote: ↑28 Aug 2024, 01:28 Multimedia Server will not stay enabled
ClamAV -> Realtime protection will not stay enabled.
Has Clam real time ever stayed enabled?
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
jpeckinp
Post by jpeckinp »
Had to uninstall then reinstall apps to get them back on the desktop.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
UncleJohnsBand
Post by UncleJohnsBand »
Why is the F5-221 still showing as compatible with TOS 6? I had upgraded and ran into some problems and was told by support that my motherboard is not compatible with TOS 6. It was pointed out that I could tell by all the lights being red on the TNAS. I had to go through an arduous process to restore back to the current level of TOS 5.
I don't want to see others have to go through what I went through.
jpeckinp wrote: ↑28 Aug 2024, 07:16
No, I don't think so - I just try to remind them they they have NOT FIXED IT YET.
Just checked after morning restart - neither is enabled (again!)
Just to add to the mix, my network bond was disabled on update and had to be reset.
Do you see if the media index is enabled when the Multimedia Server is disabled?
TMRyan wrote: ↑28 Aug 2024, 16:58
Yes Media Index ran on startup and is running now without Mutimedia Service being enabled.
Just to add, it looks like "WORKGROUP" has also been defaulted on the visible network, despite being set to something else in SMB file service.
This is getting a little crazy.
Gremlin wrote: ↑28 Aug 2024, 17:06 This is getting a little crazy.
Disabled/re-enabled SMB service. No change in displayed Workgroup (Windows 10 File Explorer)
Some minutes later, inexplicably lost contact with nas via web GUI and TNAS-PC (visible/ready but no login)
Fortunately I have console and keyboard at the ready and was able to shutdown device.
