thierrys73
France
Post by thierrys73 »
TMroy wrote: 22 Jul 2024, 23:28
thierrys73 wrote: 22 Jul 2024, 23:24
I just checked the test email feature, it work normally. please make sure your email address is correct and your device is properly connect to internet. What did you mean the remote connection not working?
email and remote connection was ok on 5.1.145
see photo when i apply in remote connexion and when i send test email
i verify my adress mail all is ok
Help me please !!
Tnas T6-423
Tnas F2-221
thierrys73
France
Hello
Sorry for the double post
FYI i try to set to factory settings with the same issues and i cant recevive the code to valid my email in the initialisation.
i have a wan adresse 90.x.x.x
Something has change in network 6.0.420 ????
it is like a have a issue with internet from my tnas in 6.0.420 only because in 5.1.145 no issues
please help me
Tnas T6-423
Tnas F2-221
MisterXY
Germany
Post by MisterXY »
Hello, there are currently 2 errors.
If I first install the TOS system on an NVME, then the NVME is the system hard drive. If I then add an HDD, the HDD also becomes the system hard drive and 4 partitions are written to the HDD.
The next error is that ISOs with the UDF file system still cannot be mounted. This worked in version 5.1.
"mount: /mnt/ISO: unknown filesystem type 'udf'."
These are the same errors as with the April beta.
thierrys73
France
thierrys73 wrote: 23 Jul 2024, 05:53 Hello
please help me
Hello
News: i succeded this morning to connect to tnas online but i dont know how !!!!! :D
cloudsync was ok too !
but i have always the issue with the notifications and the email test :evil:
failure to send test email to my email !
help me please !
Tnas T6-423
Tnas F2-221
UncleJohnsBand
Post by UncleJohnsBand »
I had no issues with the upgrade process. Took about 30 minutes.
Had to configure notifications to use my email providers SMTP settings as local always failed.
Volume shows correct Free/Used space. Storage pool shows 0 free space on the summary screen. If you open the details you can see correct free space in the detail area.
baf28
Post by baf28 »
It feels like TerraMaster are children. All companies, when they release updates, write what has changed, but here I don't see it.
1 - Where is the list of changes from 6.0.229 to 6.0.420?
2 - It is necessary to warn more specifically that all settings will be reset to factory settings.
3 - in version 6.0.420, webdav works correctly. Thank you!!!!
4 - e-mail sending does not work
Wishes:
1 - Make a firewall with geoip. The existing firewall is not completely needed, it can be removed.
2 - Add getting free Let's Encrypt certificates
3 - Add a built-in reverse proxy
4 - Fix snapshots between servers, they do not work with version 5.1
5 - Add the function of backing up system and application settings.
solovei2
Post by solovei2 »
Yes, I also confirm that sending by mail does not work. I also noticed that the USB UPS is detected, but does not turn on.
After the update, register a TerraMaster account in the Remote Access section of the Control Panel to reconfigure TNAS.online.
Can this be explained? I don't use the 'Remote Access' function(s) for any reason*. Is that an "if you need it" option, or a mandatory requirement (as it seems to read).
*As in 'I don't use a smart phone' :o
baf28 wrote: 24 Jul 2024, 16:58
First of all, I would like to thank you for your report! here is my respond to your feedback.
1. I guess you didn't read the update instructions, or you don't know what it means to replace the root file system. Updating the root file system means that almost all functions need to be re-adapted, yes, almost all. So do you need us to tell you what has been updated? If you really want to know, I can say it's all updated. It is a totally all new version.
2. Now I'm sure you didn't read the update instructions because the third item in Precautions states that all system configurations will be cleared after the update.
3. We need a practical case to investigate the issue of email sending, because we cannot reproduce this phenomenon. Would you like to cooperate with us for a remote assistance? Baby
solovei2 wrote: 24 Jul 2024, 17:15 Yes, I also confirm that sending by mail does not work. I also noticed that the USB UPS is detected, but does not turn on.
can we have a remote session to your device?
