TOS 5.1.145 (X86) is Released for Update
zimo85
Italy
Re: TOS 5.1.145 (X86) is Released for Update
Post by zimo85 »
Hi all,
i cannot update my system.
F2-220
TOS 5.1.131-00123
2 1TB HDD mounted as RAID 1 (290GB free space)
When I try, i receive the error in the image.
How can I solve this?
crisisacting
Post by crisisacting »
zimo85 wrote: ↑19 Jul 2024, 15:18
Read the important notice at the start of the thread; it links to another thread that can help with a small system partition for which this and ongoing updates will check prior to install.
zimo85
Italy
Post by zimo85 »
Thanks, I found it.
So I have to backup all data, erase all partitions on my disks and start a fresh install.
But, why I had installed 5.1.131, which has the same requirements, with a simple update?
zimo85 wrote: ↑19 Jul 2024, 17:01 Thanks, I found it.
There has always been a possibility that updating to 5.1 might work initially but there was always the likelihood it would fail eventually. {Basically when needed system space is not available}. Unfortunately users continue to update either without reading about the restrictions (in the Update Notices) or simply ignoring them. Then, those users moan about the failure and @TMSupport (and other users) would have to step in, repeat the explanations and warnings, and try to help the user with system recovery.
My belief is that @TMSupport have become more proactive by now stopping such user actions before they can do damage to themselves. The question then becomes "should those users who recklessly damage their systems be given (free) help?" :?: :arrow: :cry:
topo01
Germany
Post by topo01 »
Gremlin wrote: ↑19 Jul 2024, 18:10
To be fair, there may also be numerous users who just do know about this forum. No one can assume every user comes here to read before hitting the update button. Generally for most devices it is recommended to always update to latest available software to avoid vulnerabilities.
With initial 5.1 releases some may have run into severe problems without any warning. I wouldn't call them all "ignorant".
As I already suggested: The update warnings and descriptions of preconditions should also appear in the control panels update section. It could even be combined with a handy forum link. That would be helpful for many "ignorant" users.
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
topo01
Germany
Post by topo01 »
topo01 wrote: ↑22 Jul 2024, 02:09
To be fair, there may also be numerous users who just do NOT know about this forum.
DigitalAnalog
Australia
Post by DigitalAnalog »
But see, Terramasters are special, they are not like "most" devices. :D
F4-423
To prevent users who do not meet the update requirements from pressing the update button without understanding the update requirements, which may lead to device failures, the recent version of TOS 5.1 and the update notification for TOS 6 will only be posted on Terramaster's forum to ensure that users understand the update requirements before updating.
dianzisongyang
Japan
Post by dianzisongyang »
F2-221
TOS: 5.1.67-00217
When I try to update to 5.1.145, I get "update incompatible" error.
How can I check system partition size? To check if it is 8GB or more?
las68
Post by las68 »
Did you fixed MS LDAP integration bug shown in too long time to load LDAP users?
Your tech supp cannot fix this, so we still have to use 5.1.123
