F4-424 Memory Upgrade
Re: F4-424 Memory Upgrade
Guys, could you please advice whether f2-424 supports only own terramaster memory or I can buy the alternative model? and please advice which one? Guess any brand A DDR5 so dimm, correct? tks!
f2-424 (TOS 6)
- crisisacting
- Silver Member
, As long as it's not CU-sodimm, any brand DDR5 sodimm should be good.
You don't need to buy the most bleeding edge low CAS latency modules, since most of NAS SoC cannot benefit from that & usually the UEFI is so limited that it'll default to the base JEDEC profile for said module.
If you go with Micron (Crucial), you are always on a good way. They make very good memory modules,
and compatibility is guaranteed, because Micron does not fool around with JEDEC standards.
https://www.jedec.org/standards-documen ... -standards
