double raid 2(2 mirrors)
stp242
Finland
Re: double raid 2(2 mirrors)
Post by stp242 »
ok
Sorry, the previous information was incorrect. You can only create two types of RAID similar to D5-300 at the same time. (at this time, Single is also considered one type of RAID)
In the screenshot you provided, only three hard drives can be seen.
Now that you have seen the option to create RAID, please continue.
stp242
Finland
Post by stp242 »
ok. can i create 2 raids 2 for hdd1 and 2(first raid 2) and for hdd 3 and 4(second raid 2) and for single hdd 5 raid JBOD or something?
stp242 wrote: ↑27 Mar 2024, 00:49
So there will be three raids, it supports the use of up to two RAID at the same time.
stp242
Finland
Post by stp242 »
thanks
stp242
Finland
Post by stp242 »
Can i make Raid-2 with 4 HDDs( hdd 1 and 2 main and hdd 3 and 4 mirrors)?
GevinKe
Post by GevinKe »
stp242 wrote: ↑01 Apr 2024, 20:45
So you were talking about RAID2? (A RAID type?) D5-300 does not support such an array type.
stp242
Finland
Post by stp242 »
yes. sorry. about RAID1 (mirror)
stp242
Finland
Post by stp242 »
So,Can i make Raid1(mirror) with 4 HDDs( hdd 1 and 2 main and hdd 3 and 4 mirrors)?
stp242 wrote: ↑10 Apr 2024, 23:05
RAID1 is not used in this way.
If you want to make all the disks into one RAID while making two disks redundant,you can consider RAID10.
If you want to learn more about RAID, please refer to:viewtopic.php?t=1723
Return to “USB Series”
