TOS 5.1 - Firewall
gimatech
France
Re: TOS 5.1 - Firewall
Post by gimatech »
Ok thx for the answer.
If I have correctly understood, currently the only way to use cloud sync with a cloud provider (OneDrive for me), is to leave the NAS without firewall enabled exposed to the internet. I am right?
If yes, is there any plan to change this in the future ?
Thx
GevinKe
Post by GevinKe »
gimatech wrote: ↑14 Mar 2024, 18:18 Ok thx for the answer.
Thx
You can manually turn on and off the firewall when using the cloud disk.
gimatech
France
Post by gimatech »
:D
Best response ever!
Seriously?
The purpose is to have automatic sync, otherwise I would just copy my self the files to the NAS
gimatech
France
Post by gimatech »
I don’t know how work competitors like Synology or Qnap, but I start regretting my purchase for my use case ….
gimatech wrote: ↑14 Mar 2024, 21:24
The WAN IP of OneDrive server may be 13.107.137.11, which may vary depending on your region.
Additionally, CloudSync requires the use of an authentication server, and we have sent you the IP address of the authentication server via private message.
You can try to list these two IPs as allowed to access OneDrive.
Return to “Network”
