Hi!
Tell me please how can I update image to the new one without container recompiling?
I have created container from downloaded image. Now there is new version of image in repository. I can download it, but how it can be updated?
Docker Manager 2.0 Now is Released!
Re: Docker Manager 2.0 Now is Released!
{L_BUTTON_AT}EgorA
{L_BUTTON_AT}EgorA
If you are using seperate data volumes for your container (e.g. like for Configs and user data) you can do like this:
- Stop the container
- Create new container from latest image and same settings like old container with same volumes
- Start up new container
- If new container runs ok you can delete the old container
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
Hii,
I'm trying to update my docker using the files you provided but everytime I run them, I get "The file is incorrect and cannot be installed".
I was trying to update my `docker-compose.yml` but I'm not able to pull the image "x509 : certificate has expired or is not yet valid".
I tried to follow this : viewtopic.php?t=4243, but didn't seem to have done anything.
After looking online they said that it could be because of the docker version. So this is how i came here trying to update mine...
I've also updated my NAS to the latest version I could find.
TOS version: 4.2.40-2203011626-P1.18
Model: F2-221
Docker version: 17.05.5
Could i have some help ?
Thanks in advance !
Model: F2-221
Thanks in advance !
The Docker version is limited by the system kernel version, so TOS4 is no longer able to continue updating Docker versions.
If you want to use the new Docker version, you can consider backing up your data and upgrading to TOS5. The upgrade operation is somewhat complex. If you really need it, you can learn about it here:
viewtopic.php?t=4912
{L_BUTTON_AT}eddiemess
FWIW it looks like I had an underlying issue between upgrading from TOS 4 to TOS 5 where my filesystem was limited on disk space (one of the warnings when upgrading to TOS5). I reinstalled a fresh version of TOS 5 and docker works seemlessly now. Thank you.
I<m getting the same errors, anyone figured it out?eddiemess wrote: ↑05 Mar 2024, 08:56 Hi team
Since updating my TOS version to 5.1.123 I can't get any of my containers to start. This is roughly the error I get:
Docker: Error response from daemon: failed to create endpoint redacted on network bridge:: failed to add the host (veth4cfcda9) <=> sandbox (vethda57bc9) pair interfaces: operation not supported
Google says I'm missing some kernel components? I have reinstalled docker manager and docker engine, rebooted, deleted and recreated my containers. Nothing works.
The GUI log just says "Failed to start container"
Did you upgrade your TOS from 4.0 to 5.1?menekis wrote: ↑14 Jul 2024, 02:41I<m getting the same errors, anyone figured it out?eddiemess wrote: ↑05 Mar 2024, 08:56 Hi team
If so, uninstall docker first and then reinstall the 5.1 system, then install docker manager and docker engine.
