Cloud Sync Very Slow
pipa89
Spain
Re: Cloud Sync Very Slow
Post by pipa89 »
I have a similar problem on my nas f2 210, the terramaster app works very slowly when accessing the nas via the internet, and it also does not load the videos from the internet because of how slow the connection is (I use a global server). The app also rarely makes copies of my photos/videos automatically, I have to make them manually. Solution? greetings
TMlinda
Post by TMlinda »
{L_BUTTON_AT}pipa89
What application are you using? Can you provide the screenshot below so that we can locate your problem?an locate your problem?
pipa89
Spain
Post by pipa89 »
{L_BUTTON_AT}TMwuu
I am using the TNAS mobile app since I have the F2 210.
The problem is that if I want to access the NAS via the Internet, the connection is very slow and I cannot play the videos that I have on my NAS, I can wait many minutes that they never play. It also doesn't make automatic copies even if I have them configured.
pipa89 wrote: ↑06 Feb 2024, 23:10
Your question is not related to the topic of the post.
Regarding the issue of not being able to play videos, can you play it when you connect to TNAS using TNAS mobile on the local area network?
The TNAS Online ID connection can only provide basic access rates for browsing.
If you want to play videos remotely, you can consider opening the router port so that your can directly access your network without the need for TNAS Online ID connection.
Return to “CloudSync”
