TOS 5.1.79 (X86) is Released for Update
brunix86
Italy
Re: TOS 5.1.79 (X86) is Released for Update
Post by brunix86 »
{L_BUTTON_AT}TMLyy
Yes, the issue seems to be related to the date format "dd/mm/yyyy".
After changing the date format to a different one, the time is displayed correctly.
So, please fix the issue on date time in next release or give us a patch.
Thanks!
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1536 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
brunix86
Italy
Post by brunix86 »
Just for your information, the issue occurs with the following date formats:
  • dd/mm/yyyy
  • dd.mm.yyyy
  • dd-mm-yyyy
My NAS Environment
  • TNAS F4-424
ostaporomo
Finland
Post by ostaporomo »
{L_BUTTON_AT}brunix86
Thank you for the tip!
TNAS F2-223
TOS 5.1.79-00214
2x RAM Samsung 16GB DDR4 2133 MHZ
2x HDD Segate IronWolf ST4000VN008 4TB [RAID1]
DAS D4-300
2x HDD Seagate SkyHawk ST3000VX010  [RAID1]
2x HDD Toshiba DT01 DT01ACA300-3TB
DERIKKU
Post by DERIKKU »
After a reinstall it is work
DERIKKU wrote: ↑18 Oct 2023, 14:50 Update from 5.1.67. after 20 minutes no response. no ping no weggui no ssl. restart more than 3 times. nothing
F5-221
TNAS 10TB
RAM 10GB
quella
Post by quella »
I performed the upgrade on a F4-423 previously running TOS 5.1.67 and it appears to have gone smoothly.
However, when I attempt to login via the GUI, after waiting for it to appear, I can enter my name and password and I get the spinning icon as if it is trying to login. After a minute or so doing this, it seems to fall back to the password page and I cannot click the next. I have tried to refresh the browser page and also execute the login from two other browsers with no success. I have tried it an hour and two after the upgrade. I may wait another hour or so before doing a manual reboot. Any thoughts or next steps?
quella
Post by quella »
Just to let others know. I did a manual (power button) and wait for a clean shutdown. After that, I did a restart with the power button, and all is good again.
digi999
Post by digi999 »
Updated fine for me (F4-423) , nice to see RSync is running with Synology , good work guys :)
mokagino
Israel
Post by mokagino »
Works great. thanks!
gaz2k1uk
Post by gaz2k1uk »
FYI - I have the same issue with the time not displaying anywhere in the system.
Setup:
System: F2-422
OS: TOS 6.0.535
HD: x2 IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
desallesp
Post by desallesp »
Loaded perfectly
