With a 2GB system partition, your TNAS will not be able to update to TOS 6, the pre-update check will fail.
TOS 6 is Getting Closer to You...
Re: TOS 6 is Getting Closer to You...
Re: TOS 6 is getting closer to you...
Not able to tell you such details at this moment, sorry.crisisacting wrote: ↑15 Sep 2023, 12:38 Like other recent TOS releases, this will use the current LTS build of the Linux kernel, correct? TOS 6 should be based off Linux LTS kernel 6.1.×?
Pre-announcing products & software with no timeline and no compatibility information is very risky play for business.
By doing so, you may want to have your existing community feeling engaged by such teaser, fine.
Now, imagine I'm a prospect buyer, pondering which product to buy, and thinking about how-long my product will be supported: will such teaser with no timeline and no baseline requirements be an incentive to buy my new product now?..... Noooooo
I won't want to buy now a product that may not be supported on 6.x: I'd rather wait or buy somewhere else.
Basically such preliminary teaser is likely to adversely affect TM short-term revenue.
Now you've ran that teaser route, you'd need to quickly give some more insights (and then timely deliver on promises), for customers to draw favourable conclusions and buying decisions.
Here we go again! Only just updated to the last one which needed a full system reset just to accommodate the 2gig partition, and now It's going to take the same again if we want to update, and I have not noticed any real advantage anyway.
No, no, no..., I can't tell you now. You will know such details when we are ready to tell. hahaha...macmpi wrote: ↑15 Sep 2023, 15:33Pre-announcing products & software with no timeline and no compatibility information is very risky play for business.
With 2GB partition, you better stick on 4.2.x/5.0.x, DO NOT even update to 5.1.
You may also let us know when you are ready to get our money then...though it might likely be too late.
Not now.
Guess many will consider that, and follow such guideline: good luck!...
Consider to update Glibc version to at least 2.28
Vers 2.21 include in TOS 5.1 is almost 8 years old.
