It is known that when the 2.5G network port is connected to a 100M router, the 2.5G network port light does not light up.
We guess that your router may be of 100M standard. It is recommended that you use the latest standard Gigabit router or a higher standard router.
BIOS or OS setting? RJ45 Socket interface and LAN font panel LED's Not working!
Re: BIOS or OS setting? RJ45 Socket interface and LAN font panel LED's Not working!
[at=TMzethar post_id=29654 time=1694567466 user_id=2405][/at]
Morning...
of your focus on this considering the sea of support request you have.
Revamp
TP-Link TL-MR6500v. WAN connection type: RJ-45. Wi-Fi band: Single band (2.4 GHz), Wi-Fi standard: Wi-Fi 4 (802.11n), WLAN data transfer rate (max): 300 Mbit/s. Ethernet LAN interface type: Fast Ethernet, Ethernet LAN: data transfer rate: 10,100 Mbit/s, Cabling technology: 10/100Base-T(X). Mobile network generation: 4G, 3G standards: DC-HSPA+, HSPA, HSPA+, UMTS, 4G standard: LTE-TDD & LTE-FDD. Supported security algorithms: 64-bit WEP, 128-bit WEP, WPA, WPA-PSK, WPA2, WPA2-PSK
Morning...
- Thank you for taking the time to bringing this to my attention and explain this..
- Go figure..
I'm shocked to read the spec highlighted below..
Revamp
F4-423 (24/08/2023)
20GB
2 x M.2 SSD NVMe 500GB 970 EVO Plus
(1 For TOS5 Boot and Apps - 1 For Hyper Cache) with a custom fabricated heatsink (L shaped) to cover both
4 x 1TB IronWolf in TRAID
TOS 5.1.67 + @current
TOS Language - English
20GB
Time for a new 5G MiMo router as part of a new two VLAN build.
Any suggestions of a good device to purchase to complement to accommodate a dual VLAN build would be most appreciated amounts the sea of kit out on the web..
Revamp
Revamp
F4-423 (24/08/2023)
20GB
20GB
