[ Caddy ] The ultimate web server
AES
Re: [ Caddy ] The ultimate web server
Post by AES »
I don't understand anything, except that I'm not the idiot here.
I installed two dependent packages, and they didn't start. There are no symbol logs in TOS. I'm not an idiot; it's obvious that TOS is the latest version. Why should I try to access some web interface if it didn't start in TOS? The whole logic is that if it didn't start, it doesn't work, and trying to figure out how to open the web interface is a waste of time.
Okay, a new version came out, I somehow found it and clicked delete. It says it's installing, and it doesn't remove the package. While I was writing this, it's still "installing."
I repeat, TOS is a child's creation, and nothing works in it.
I can't uninstall the Caddy package now.
TerraMaster F8, TerraMaster F2-425, Syno 218+
AES
Post by AES »
How long do I have to wait for the package called "installation" to be removed?
I didn't force this nonsense; I bought it a year ago and didn't do anything special. So it doesn't work on its own, it simply DOESN'T WORK.
I'm surprised anyone thinks otherwise. It's clearly because their brains aren't working. Maybe they're used to setting up a NAS themselves, but I'm not.
Why does this stupid forum keep logging me out?
AES
Post by AES »
AES
Post by AES »
I updated the version through the settings. But this crap keeps saying it's installing, even though I've clicked the delete button several times.
:evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
AES
Post by AES »
Now I have to reboot this whole thing?!
AES wrote: 22 Sep 2025, 03:50 I don't understand anything, except that I'm not the idiot here.
When i said to access web interface, i was referring to the app frontend. From there you have some more option to debug.
AES
Post by AES »
It stopped deleting. I clicked the "Enable" button. I got the same error as before: "Operation failed!"
I don't understand how I can access the app if the TOS reports a launch error.
There should be a button to open the web interface. I shouldn't have to figure out the address myself.
I feel like everyone on this forum is making fun of me. Why should I have to sit there and guess how to open the web interface of an app that's not running?
https://192.168.1.108:5443/modules/Caddy/www
404 Not Found
nginx/1.18.0 (Ubuntu)
Okay... I found a button, it opens a web interface, it actually works, even if the application is not running according to TOS.
https://f8-terramaster.local:5443/Caddy/?page=8
AES
Post by AES »
Your message contains 23384 characters.
The maximum number of allowed characters is 10000.
AES
Post by AES »
20/09/25 16:45:38 Will use /Volume1 to store config files
20/09/25 16:45:38 The main volume is /Volume1
20/09/25 16:45:38 Config folder will be created /usr/local/@APP_CONFIG/Caddy
20/09/25 16:45:38 config symlink doesn't exist, will be created
{"level":"info","ts":1758375939.129874,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758375939.1301723,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758375939.1302319,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758375939.1311386,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758375939.1311688,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758375939.1599054,"msg":"maxprocs: No GOMAXPROCS change to reset"}
Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp: lookup localhost on 8.8.8.8:53: no such host
Error: caddy process exited with error: exit status 1
20/09/25 16:46:28 Will use /Volume1 to store config files
20/09/25 16:46:29 The main volume is /Volume1
20/09/25 16:46:29 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758375989.7569447,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758375989.7571986,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758375989.757265,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758375989.7587957,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758375989.7588294,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758375989.787827,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 16:46:34 Will use /Volume1 to store config files
20/09/25 16:46:34 The main volume is /Volume1
20/09/25 16:46:35 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758375995.5172184,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758375995.51743,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758375995.5174687,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758375995.5183492,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758375995.518371,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758375995.5458124,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 16:47:47 Will use /Volume1 to store config files
20/09/25 16:47:48 The main volume is /Volume1
20/09/25 16:47:48 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758376068.883138,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758376068.8833516,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758376068.883399,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758376068.8843281,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758376068.8843746,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758376068.9138293,"msg":"maxprocs: No GOMAXPROCS change to reset"}
AES
Post by AES »
20/09/25 16:50:14 Will use /Volume1 to store config files
20/09/25 16:50:14 The main volume is /Volume1
20/09/25 16:50:15 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758376215.5896924,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758376215.5898905,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758376215.5899458,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758376215.59072,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758376215.590744,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758376215.6198442,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 16:50:26 Will use /Volume1 to store config files
20/09/25 16:50:26 The main volume is /Volume1
20/09/25 16:50:27 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758376227.5356233,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758376227.5358493,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758376227.5359027,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758376227.5366924,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758376227.5367134,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758376227.5660293,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 16:50:36 Will use /Volume1 to store config files
20/09/25 16:50:36 The main volume is /Volume1
20/09/25 16:50:37 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758376237.528549,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758376237.5288806,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758376237.5289247,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758376237.529907,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758376237.5299416,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758376237.5590425,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 20:33:01 Will use /Volume1 to store config files
20/09/25 20:33:01 The main volume is /Volume1
20/09/25 20:33:01 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758389582.3266926,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758389582.3268948,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758389582.3269637,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758389582.3277762,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758389582.3278005,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758389582.3552356,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 20:33:06 Will use /Volume1 to store config files
20/09/25 20:33:06 The main volume is /Volume1
20/09/25 20:33:06 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758389587.1111147,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758389587.1113687,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
{"level":"info","ts":1758389587.1114275,"msg":"using config from file","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile"}
{"level":"info","ts":1758389587.1131225,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"warn","ts":1758389587.1131566,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/@APP_CONFIG/Caddy/Caddyfile","line":3}
{"level":"info","ts":1758389587.1411,"msg":"maxprocs: No GOMAXPROCS change to reset"}
20/09/25 20:33:32 Will use /Volume1 to store config files
20/09/25 20:33:32 The main volume is /Volume1
20/09/25 20:33:32 Config folder exist at /usr/local/@APP_CONFIG/Caddy
{"level":"info","ts":1758389613.2959816,"msg":"maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined"}
{"level":"info","ts":1758389613.2962706,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":7269005721,"previous":9223372036854775807}
