OneDrive
Re: OneDrive
We are contacting OneDrive now, some features have been blocked, and a totally new release will be posted soon. Sorry for all the troubles.
rgblack316
Re: OneDrive
Post by rgblack316 »
The OneDrive application will not complete the installation on my NAS. It gets to 50% and never proceeds further.
Re: OneDrive
OneDrive could not be used for the moment, please wait for the new version.
mitch478
Re: OneDrive
Post by mitch478 »
Does anyone get a expired cert for https://oauth.terra-master.com/ when syncing one drive. looks like cert expired 12 May 2020
Re: OneDrive
Yes, please update your Onedrive sync app.
Gareth
Re: OneDrive
Post by Gareth »
mitch478 wrote: ↑20 Jun 2020, 01:09 Does anyone get a expired cert for https://oauth.terra-master.com/ when syncing one drive. looks like cert expired 12 May 2020
Yes, this is very poor and should be fixed immediately. I'm seeing the cert as date valid so it's likely a different issue now. Really bad though whatever it is.
gargs.manish
Re: OneDrive
Post by gargs.manish »
I am facing issues with OneDrive sync as it's not syncing deleted files changes i.e. if the file is deleted on the cloud, it's not deleting on NAS. It only syncs download/upload changes, nothing else. Also, it doesn't start syncing automatically and have to stop/start the task to make it work.
Re: OneDrive
Thank you for your feedback. We have modified the problem of not deleting files synchronously. After the test is passed, it will be updated to the application center. The synchronization cannot be started automatically because its default synchronization interval is relatively long. We have added the function of setting the synchronization interval by ourselves in the new version. The new version is being tested, if the test passes today, we will update to the application center. You can pay attention to the update of this application.
gargs.manish
Re: OneDrive
Many thanks for the prompt response and looking into this.
Do you mean that I will be able to set the synchronization interval?
Perhaps the app could use OneDrive Webhook to start automatically on change event.
gargs.manish
Re: OneDrive
There is still no update to OneDrive app. When this will be resolved?
Also would the update handle moving file within the sync folder?
Return to “CloudSync”
