TOS 5.1.41 (X86) is Released for Update
kg223
Re: TOS 5.1.41 (X86) is Released for Update
Post by kg223 »
kg223 wrote: 22 Jul 2023, 12:20 Updated TOSHIBA 5.1.40 to 5.1.41 everything is fine. VLC started working via UPnP! On 5.1.40 VLC via UPnP did not work.
thumbnailDaemon loaded the processor on 53% , what should I do? The system started working slowly, stopped working transmission
TNAS: F2-223, 32GB Ram, TOS 5.1.41, 1x3TB WDRed ext4
kg223
Post by kg223 »
kg223 wrote: 22 Jul 2023, 12:41
After about 1 hour, everything returned to normal, the CPU load is 1%!
ERESEN
Post by ERESEN »
Installation went very well on F4-420
Kind regards
O.T.Eresen
sybarix
Post by sybarix »
Upgraded F2-221 from 5.1.40 to 5.1.41 with no issues to report :D
mmalchuk
Post by mmalchuk »
Updated from 5.1.24 to 5.1.41 and uptime still show 149 days! Is this normal? why nas sounds 'beep' but not rebooted?
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
{L_BUTTON_AT}mmalchuk
It is found that your device model is of the previous generation, and it basically uses TOS4. The partition structure from TOS4 is not suitable for the new version of TOS5. Please install it back to TOS5.1.24. Or you can refer to this backup and reset the hard disk: viewtopic.php?f=28&t=4912
mmalchuk
Post by mmalchuk »
TMzethar wrote: 01 Aug 2023, 18:33 It is found that your device model is of the previous generation, and it basically uses TOS4.
kidding? it flawlessly run TOS5 since 5.0.x versions for almost an year!
mmalchuk
Post by mmalchuk »
mmalchuk wrote: 01 Aug 2023, 17:54 2023-08-01_12-48-51.png
waiting for a couple hours and issuing the 'reboot' command from the ssh helps)
joka388
Austria
Post by joka388 »
I have a strange error here. I reset the F2-221 with firmware 5.1.41 and everything works as it should. However, as soon as I enter the start times for my NAS (it starts at different times every day), the transfer rate drops from 113 Mb/s to just 22 Mb/s. I'm starting to despair here. Reinstalled again and everything works until I enter the start times for my NAS. The transfer rate from the Windows PC to the NAS drops again to 22 Mb/s.
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
{L_BUTTON_AT}joka388
You can refer to the link below to troubleshoot the problem: viewtopic.php?f=77&t=527 Or you can try another computer.
