can add camera but no live view
A CCTV monitoring and recording application
TMtina
Re: can add camera but no live view
Post by TMtina »
dataonly wrote: 23 Mar 2024, 13:07
Try logging in with http.
John
Post by John »
HI, I have the same issue with the Black Screen for the live feed...but resolution change didnt solve it....its for a Tapo C200..recoding is fine..just live feed not working...any ideas? Thank you
What format is the video stream output from your camera? Maybe your browser is not compatible with the video format, resulting in the inability to view the video in real-time.
GevinKe
Post by GevinKe »
John wrote: 10 Jun 2024, 00:45 HI, I have the same issue with the Black Screen for the live feed...but resolution change didnt solve it....its for a Tapo C200..recoding is fine..just live feed not working...any ideas? Thank you
1. Please check whether HTTPS is used for login, please change it to HTTP.
2. Please check whether the camera encoding format is H.265, please change it to H.264.
John
Post by John »
Hi. Apologies for the stupid question but how and where so I change from https to http please. Thank you.
IrisLi
Post by IrisLi »
You can check your network settings in Control Panel - Network - General. The default port for accessing http links is 8181.
koshari
Australia
Post by koshari »
doesnt work here either, just grey screen,
Return to “Surveillance Manager”
