TOS 5.1.40 (X86) is Released for Update
Re: TOS 5.1.40 (X86) is Released for update
{L_BUTTON_AT}Gremlin
You can try updating the Multimedia Server and re-enabling the Multimedia Server .
norman0
Germany
Post by norman0 »
The update to version 3.2.79 of the Multimedia Server App solved my problem. The media server is visible in the network again. I then had to recreate the Media Index.
F2-220 4GB + 2*Seagate IronWolf 4TB
TMRyan wrote: 05 Jul 2023, 11:47 [at=Gremlin post_id=28214 time=1688508026 user_id=6052][/at]
Yes, update of MMserver appears to have worked. Waiting on indexing to finish :cry:
ERESEN
Post by ERESEN »
TOS 5.1.40 is installed and working, Thanks.
How can I find improvements in TOS 5.1.40?
Kind regards
O.T.Eresen
Lord.mjj
Post by Lord.mjj »
Initially I installed TOS5.1.37 for my 223, the system partition is 8GB.
After updating to this version, my encrypted shared folder can no longer be opened, why?
lol
{L_BUTTON_AT}Lord.mjj
There is a problem with the encryption rules of the 5.1.37 version, we have fixed it in 5.1.40.
However, encrypted shared folders created on 5.1.37 cannot be decrypted in subsequent versions.
We recommend that you reinstall back to 5.1.37 and export the data from the encrypted shared folder. After updating to 5.1.40, you can continue to use the encrypted shared folder.
Optimus22Prime
Post by Optimus22Prime »
Are this update applicable to U8-722-2224?
Gremlin wrote: 05 Jul 2023, 16:49 Waiting on indexing to finish :cry:
Email notification @:11:54 today
Media indexing is complete. Total number of new indexes: 202 (pictures: 202; audio files: 0; videos: 0; documents: 0 )
Device name: NAS-1
Model: F5-221
TOS version: TOS_X642.0_5.1.40
TNAS System Notification
Control panel data:
Last run: 2023-07-04 15:49:21
Control panel data appears unreliable.
Marshal
Post by Marshal »
TMRyan wrote: 05 Jul 2023, 11:47 You can try updating the Multimedia Server and re-enabling the Multimedia Server .
There is no new version 3.2.79 of the Multimedia Server in APP Center
Marshal wrote: 05 Jul 2023, 20:12
Well, I found it and installed it. Just checked and that is what I got. Release date June 21.
