TOS 5.1.34 (X86) is Released for Update
zedmel
Re: TOS 5.1.34 (X86) is Released for update
Post by zedmel »
F2-210 have been updated. No problem, no more slow transfer , seems to be like the 5.1.76.
No bug so far.
:D
digi999
Post by digi999 »
Upgraded my F4-223 no issues , seems to run a tiny bit quicker than 5.1.33 , looks nice thankyou
norman0
Germany
Post by norman0 »
This update solves my problems with hard disk hibernate and media index.
F2-220 4GB + 2*Seagate IronWolf 4TB
dhfh522
Post by dhfh522 »
Receiving a new error message every few minutes from an active client on this release:
[Sun May 7 05:49:55 2023] CIFS: VFS: \\Terramaster sends on sock 00000000e8f22a65 stuck for 15 seconds
[Sun May 7 05:49:55 2023] CIFS: VFS: \\Terramaster Error -11 sending data on socket to server
Setup:
TOS 6.0.650
T9-423(16GB)
1 x Intel 1Tb 670P Hyper-Cache
9 x 3TB HGST Ultrastar 7K4000
8 - members in TRaid array, 1 - Hot Spare
1 Storage pool with 2 Volumes
Backup
D5-300C
4x14TB ST14000NM0018 in TRaid array
1 Storage pool with 1 volume
Tricky
Post by Tricky »
Took me two goes to get the update to stick, had to re-initialize to 33 and then got 34 to update, the media index has gone and had to recreate, and although the media server doesn't disconnect/turn off when a TV connects it still not seeing any content, and why is it that new folders 1 to 4 are created with every update?
dhfh522 wrote: 07 May 2023, 19:29 Receiving a new error message every few minutes from an active client on this release:
where did you get such log? from your computer?
Tricky wrote: 07 May 2023, 22:21 Took me two goes to get the update to stick, had to re-initialize to 33 and then got 34 to update, the media index has gone and had to recreate, and although the media server doesn't disconnect/turn off when a TV connects it still not seeing any content, and why is it that new folders 1 to 4 are created with every update?
Do you have four drives on your TNAS as single drive? and you wipe your data and recreate volumes by using "Default option" in reinstallation?
dhfh522
Post by dhfh522 »
The log is from my ubuntu server that runs off the same switch. ICMP traffic is stable with no network drop outs.
Setup:
TOS 6.0.650
T9-423(16GB)
Backup
D5-300C
Tricky
Post by Tricky »
TMroy wrote: 07 May 2023, 23:05
Nope! 2 as RAID and the rest as single disk, and I always use the custom option to reinstall.
Dave11
Post by Dave11 »
Updated from 5.1.33 this caused lots of issues, Raid array re-sync started from what i could see when i got into the web interface, but the device crashes after ~5-10 minutes of this due to 'tcp_recvmsg' function stalling on all CPU cores, same thing every reboot.
Currently reinitialising to 5.1.33, waiting for this one to re-sync now it would seem .....
Note to self don't update the TOS software as it almost never ends well.
F2-421
