[ Kavita ] Self-hosted digital book library
scottish
Re: [ Kavita ] Self-hosted digital book library
Post by scottish »
i have managed to install but it won't enable, is there anything i should try to get it to enable
When i go into the gui and try starting nothing happens
the Start .log is
26/05/25 20:51:58 Will use /Volume1 to store config files
26/05/25 20:51:59 The main volume is /Volume1
26/05/25 20:51:59 Config folder exist at /usr/local/@APP_CONFIG/Kavita
26/05/25 20:51:59 config symlink doesn't exist, will be created
MODCONFIGPATHHOME=/home/Scottish21/MOD_CONFIG/Kavita
MODCONFIGPATH=/usr/local/@APP_CONFIG/Kavita
MAIN_VOLUME=/Volume1
HOME_VOLUME=/Volume1
[Kavita] [2025-05-26 20:52:01.172 +01:00 1] [Fatal] Host terminated unexpectedly
System.TypeInitializationException: The type initializer for 'Microsoft.Data.Sqlite.SqliteConnection' threw an exception.
---> System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
---> System.DllNotFoundException: Unable to load shared library 'e_sqlite3' or one of its dependencies. In order to help diagnose loading problems, consider using a tool like strace. If you're using glibc, consider setting the LD_DEBUG environment variable:
/Volume1/@apps/Kavita/bin/program/e_sqlite3.so: cannot open shared object file: No such file or directory
/lib/libc.so.6: version `GLIBC_2.28' not found (required by /Volume1/@apps/Kavita/bin/program/libe_sqlite3.so)
libe_sqlite3.so: cannot open shared object file: No such file or directory
/Volume1/@apps/Kavita/bin/program/e_sqlite3: cannot open shared object file: No such file or directory
/Volume1/@apps/Kavita/bin/program/libe_sqlite3: cannot open shared object file: No such file or directory
I can send your the whole log if that would help
No need to send the complete log. Unfortunately, the GLIBC version available on TOS5 is too old for the latest versions of Kavita. Maybe is time for you to update to TOS6 if possible ? Also i dont have anymore a NAS running TOS5 to test the TOS5 apps...
probably i will come with a solution for TOS5 x86
Download and install ModBaseMusl + MUSL. Then download again latest Kavita for TOS5 and install it. Let me know if it will work.
Metaladict
Peru
Post by Metaladict »
I recently upgraded from TOS 6 to TOS 7, and the KAVITA launcher isn't working for me, even though the app itself is working fine. Do you know how to fix the launcher issue?
Metaladict
Peru
Metaladict wrote: 24 Jul 2026, 04:15 I recently upgraded from TOS 6 to TOS 7, and the KAVITA launcher isn't working for me, even though the app itself is working fine. Do you know how to fix the launcher issue?
I found the solution in the forums themselves; apparently, TOS 7 isn't included with PHP 7.4, so you have to install it from the App Center.
https://tmnascommunity.eu/2026/07/12/to ... -for-apps/
petrose
Denmark
Post by petrose »
It seems that TOS 7 install of PHP 7.4 is no longer working !
It stops around 20% of install process:
I reported it to TOS7 Forum prior to Final Version, and after I upgraded to Final version, problem still persist.
BR PetRose
My TNAS: F8 SSD Plus, now with TOS7 Final version along with 1+3x2 TB SSD sticks, formatted as BTRFS and using TRAID
petrose
Denmark
Post by petrose »
petrose wrote: 26 Jul 2026, 23:56 It seems that TOS 7 install of PHP 7.4 is no longer working !
Post this finding, I perused the syslog and found this, likely to cause the issue:
Jul 26 17:50:26 SonjaNAS application[15873]: DEBUG /usr/bin/systemctl disable PHP74
Jul 26 17:50:26 SonjaNAS application[15873]: Shell execute error. Error=Failed to disable unit: Unit file PHP74.service does not exist.#012: exit status 1
Jul 26 17:50:30 SonjaNAS application[50603]: E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Jul 26 17:50:30 SonjaNAS application[15873]: Application install failed:install error
Jul 26 17:50:31 SonjaNAS application[15873]: App operation error. AppID=PHP74 Operate=install Error State=2
Jul 26 17:50:31 SonjaNAS application[15873]: App state will be deleted. AppID=PHP74
Is this a good idea to have me running the command suggested 'dpkg --configure -a'
BR PetRose
PHP74 should install correctly and is an official app in the App Store
Is best to contact Terramaster if you encounter any issue during installation
