RAID Manager cannot recognize the hard drive?
FAQs and instructions only for USB series raid storage
VJVis
Re: RAID Manager cannot recognize the hard drive?
Post by VJVis »
Has this issue been resolved? What is the solution to this issue? I have the same problem. Terramaster Raid manager software does not detect my device. Windows File Explorer has no issues reading and writing into drives, so I know that my D5-300C is working fine and all five hard drives in it are fine.
Please share the solution.
The software does not support your model,your machine model is TerraMaster D5-300C,
Applicable models: TerraMaster D5-300
jacks122
Post by jacks122 »
Dear friend i have got this Hitachi 12TB 7200RPM SATA 6Gb/S 3.5-Inch Hard Drive from amazon and nexthdd
how its relaible kindly suggest me thanks
TMS
Post by TMS »
Generally speaking, if this disk is enterprise-level or nas dedicated, it is available, but we cannot guarantee compatibility.
It is recommended to use a compatible hard drive,refer to this link https://www.terra-master.com/global/compatibility/
brey
Post by brey »
Hi All. I have the same problem. My setup was created with RAID manager version 0.09.65 on a Mac running High Sierra. I now moved to a new Mac running Catalina and downloaded the new version from your site (0.09.78). However, the manager doesn't recognise the RAID setup. The DAS works fine though. Anyway, I can resolve the issue?
brey
Post by brey »
Anything?
TMS
Post by TMS »
What is your DAS model?
brey
Post by brey »
D5-300
brey
Post by brey »
Can you at least tell me if there is a chance to make this work?
TMS
Post by TMS »
Have you tried the troubleshooting for the first post of this thread?
Is it possible to let our engineer check it remotely?You can send an email to our tech team to confirm it.
Return to “USB Series”
