i have a F2-210 running 4.2.41 and can copy a file that is many gigs in size to and from the nas drive so it is NOT a design issue as mine is working perfectly, if it was a design flaw then mine wouldnt be working
(ignore the speed im on wifi)
System fails to be useful
- sianderson
- Silver Member
Re: System fails to be useful
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Well I'm happy for yousianderson wrote: ↑10 Apr 2023, 22:44 i have a F2-210 running 4.2.41 and can copy a file that is many gigs in size to and from the nas drive so it is NOT a design issue as mine is working perfectly, if it was a design flaw then mine wouldnt be working
Thing is, it doesn't work for me; I just did another hard-reset, re-installed the firmware, re-formatted the drive, re-attempted the copy and... same result. Crash.
I would love to know what's the difference... Would you mind to access your NAS with the terminal and copy and paste the output of the 'dmesg' command?
Thanks!
