F5-221 - High Resource Utilization, System Not Accessible After ~15 Minutes
Mascott
Re: F5-221 - High Resource Utilization, System Not Accessible After ~15 Minutes
Post by Mascott »
TMSupport wrote: 20 Mar 2023, 18:02 Please try to log in to the SSH terminal and disable the btrfs quota.
btrfs quota disable /Volume1
Circling back on this in the interest of documentation, I was able to take this step by SSHing in ASAP after boot and the system has been running smoothly in a stable state for an hour with seemingly no loss of data.
My expectation is that this change would not persist across reboots and next time the system comes down for whatever reason, I would run into the same issue - is there a way to make this change persist across reboots, or is there any downside to disabling the quota that I need to be aware of? Is the RAID5 redundancy any less stable?
Please update to 5.1.33
DERIKKU
Post by DERIKKU »
same here and samba config is also not persist after reboot. TOS 5.1.33 with btrfs TRAID
the nas is every day on the same time off for access only power reset will work
F5-221
TNAS 10TB
RAM 10GB
Did you mean the smb disabled after your TNAS reboot?
DERIKKU
Post by DERIKKU »
TMroy wrote: 23 Apr 2023, 23:56 Did you mean the smb disabled after your TNAS reboot?
no. when i delete in samba.conf usbshare1 and usbshare2 (i dont have a usbdrive), after a reboot this is also in the samba.conf and in the samba network i see this folder (without i see this in the tos webadmin). When i delte this in samaba.conf than i dont see this folder in the network
F5-221
TNAS 10TB
RAM 10GB
{L_BUTTON_AT}DERIKKU
The problem you mentioned seems to have little to do with the situation described in the topic, and the modification of "btrfs quota disable" can continues to work.
Regarding what you said about usbshare1 and usbshare2 showing up every time you boot. We recommend that you keep the phenomenon, generate and download a log report at TOS > Technical Support > Issues Report, then send to us for analysis.
DERIKKU
Post by DERIKKU »
{L_BUTTON_AT}TMzethar
well i have do this, but the log is to big for sending. and i think it is the same. btrfs quota disable and other things is after a reboot back to default?
F5-221
TNAS 10TB
RAM 10GB
No, btrfs quota disable doesn't reset after reboot. As for other configurations or services, what exactly do you need to know?
Regarding the log report that is too large, you can upload it to NAS or network disk, and provide it to us through the sharing link.
Mascott
Post by Mascott »
TMroy wrote: 20 Apr 2023, 09:45 Please update to 5.1.33
For further documentation, updating to the latest version of TNAS does seem to fix this issue between reboots and I have not had a recurrence of the problem running a BTRFS TRAID volume. I was not aware there was a new version available, as the system update utility in TNAS 5.1.24 did not display that a new version was available when checking for updates.
Return to “System Resources”
