[ Tailscale ] VPN to connect your team and devices easy
wuyto
Re: [ Tailscale ] VPN to connect your team and devices easy
Post by wuyto »
Now i get the following error from the ssh terminal while running the last command from the other topic
/etc/init.d/php-fpm start
ERROR: [pool TOS] cannot get uid for user 'root'
Are you logged in with your superuser account? Try to restart your NAS
TM220user
Post by TM220user »
"Applicable TOS4: 4.1.27 or later versions - on request"
Add another request for a TOS 4 version please!! And TY!
F2-220 (x86 flavored!)
wuyto
Post by wuyto »
outkastm wrote: 01 May 2023, 01:13 Are you logged in with your superuser account? Try to restart your NAS
Solved! That was the issue, thank you very much.
updated and added TOS5 arm
Warez
Post by Warez »
Hello, please update this app.
The Tailscale dashboard warns for version upgrade.
Thank you for the great work!
Warez
Post by Warez »
Thank you!
