creating camera doesn't work
A CCTV monitoring and recording application
freddye83
Re: creating camera doesn't work
Post by freddye83 »
My TOS version is 5.0.176 Bios MAPL0304V17 - F5-221
TMlinda
Post by TMlinda »
{L_BUTTON_AT}freddye83
Uninstall the application in the application center, check "Also delete all configuration files of this application", and then try to reinstall the application.
freddye83
Post by freddye83 »
I do it, but not working. Same problem.
TMlinda
Post by TMlinda »
For your question, please contact our technical team to conduct a remote inspection for you, you can find the contact information in my signature.
freddye83
Post by freddye83 »
It's not possible for me to open my network.
I wait for a stable version.
For now, i use ispy on docker and it's wornderfull.
Rick
Netherlands
Post by Rick »
New version Same problem (none of the 5 cameras)
freddye83
Post by freddye83 »
idem for me
freddye83 wrote: ↑08 Mar 2023, 20:35idem for me
You can update TOS 5.1.24 and then reinstall the surveillance app. When using this version of surveillance, do not force TNAS to shut down. The current version of forced shutdown will cause the page to fail to start normally. You can also use it after we update the application and system this week or next week
freddye83
Post by freddye83 »
no change after upgrade TOS.
Same problem
freddye83
Post by freddye83 »
I update today with V0.1.06 (TNAS 5.1.24), same problem...
Return to “Surveillance Manager”
