open vpn local network access
mithito
Re: open vpn local network access
Post by mithito »
To add more context...
Server:
TOS 5.1.24-00324
VPN Server 2.0.48
Client:
Android 12 using OpenVPN apk.
It has been confirmed that this problem does exist on the OpenVPN of the VPN service app, and we will fix it in a later version.
demefromhell
Post by demefromhell »
same problem for me!
demefromhell
i'v found a resolution!
first you need to change a parameter in the .ovp client configuration file:
remove the comment symbol # before the redirect-gateway option def1 to enable the redirection.
after that you need to check the "server.conf" file for the Ovpn server on the tnas, findable in the path etc/openvpn:
you must verify that the push route set in the line 3 match with the static ip pool you've set on the vpn server app.
for example in my case i have set the ip pool 192.168.2.1 and i insert in the push command push 'route 192.168.2.0 255.255.255.0'
this is because the app does not write the ip pool that is chosen by the user and keeps the default one 172.10.11.0 255.255.255.0
gexpo
Italy
Post by gexpo »
SO, this is the solution to the issue?
Approved by Terra-Master Team also?
However, thanks a lot! :idea:
artical
Post by artical »
is this issue now resolved in latest 5.1.67 version of the software?
{L_BUTTON_AT}artical
The TOS update does not involve this application. Please wait for the application version update.
Ortof
France
Post by Ortof »
I just found the solution for the VPN server. So, I looked into it on my end.
I did:
cd /etc/openvpn
cat server.conf
vi server.conf
I modified the
push 'route 192.168.1.0/24 255.255.255.0'
:x!
And it works.
Return to “Network”
