Disk size upgrade Raid 1
epiq
Re: Disk size upgrade Raid 1
Post by epiq »
Thanks, I did it and awaiting for reply.
Righty01
Post by Righty01 »
Hi
I'm confused here .
I have got raid 1 but want to goto raid 5 but it seems when I add my new drive which makes 3 drives it will stays on raid 1.
What do I need to do to change over to raid 5 .
Cheers
Jas
You should select "upgrade RAID" when the new drive was added.
TOSMC
Post by TOSMC »
Hi!
I have a similar problem too.
I have a F4-220 with 4 Hard Drives of 3 Tb each configured in RAID 10.
Two hard drives give error, so I bought two HDDs of same brand and capacity.
I followed what indicated here:
viewtopic.php?f=25&t=1226&p=6469&hilit=replace#p6469
I changed the first HDD, went in "Storage Pool" but in Volume#1 TOS tell me that "Hard drive is not detected" and "Edit" button isn't available for RAID Rebuild/Repair.
However all the 4 disks (included the new one) are listed in "Hard drive", I also checked the new Hdd (the first one) and it's error free.
Where I'm wrong?
Is it possible to let our engineer check it remotely? You can send an email to our tech team to confirm it.
