Docker config gone after update
Discussion about Docker
XFNeo
Re: Docker config gone after update
Post by XFNeo »
{L_BUTTON_AT}TMSupport
Have you fixed this issue?
XFNeo
Post by XFNeo »
Is the issue fixed in TOS 5.1.31 ?
MooieBoot
Post by MooieBoot »
Or docker update or TOS update made my connected folders readonly.
That's what the app says, but they're all empty/inaccessible.
Had to re-assign folders for all docker instances.....
{L_BUTTON_AT}MooieBoot
This issue is still being fixed. May I ask if the network configuration of the error container you used before is all "HOST"?
davidecavestro
Post by davidecavestro »
Guys, I just noticed that upgrading the Docker manager app (which in turn seems to deploy containerd and the whole docker stuff)
the daemon.json configuration used by the daemon and hosted at path /Volume1/@apps/docker/conf/daemon.json
is simply overwritter
so that any customization applied there - such as dns, logging opts - gets lost
ahem... Is this wanted?
TOS 5.1.40
Docker manager 1.2.2
{L_BUTTON_AT}davidecavestro
This file has nothing to do with Docker and container configuration.
You can find configuration files in /Volume1/DockerData/containers/container id.
davidecavestro
TMzethar wrote: 03 Aug 2023, 19:23 This file has nothing to do with Docker and container configuration.
I'm sorry to disagree. When I run
pgrep -a dockerd
I get
11898 /Volume1/@apps/docker/dockerd/bin/dockerd --config-file=/Volume1/@apps/docker/conf/daemon.json
So at path /Volume1/@apps/docker/conf/daemon.json there's the config with params for the docker daemon. GIven that docker advanced users sometimes need to customize it (i.e. to set custom DNS or change the IP address range to avoid conflicts, or change the logging driver for better performance, etc). My point is that packaging this file along with the app implies loosing any customization at every upgrade. Am I wrong?
TMzethar wrote: 03 Aug 2023, 19:23 You can find configuration files in /Volume1/DockerData/containers/container id.
I agree that /Volume1/DockerData/containers/container id is the path where docker by default stores the state/config of each specific container, such as the resolv.conf previously mentioned. It's not my point in this case.
davidecavestro
TMzethar wrote: 03 Aug 2023, 19:23 This file has nothing to do with Docker and container configuration. You can find configuration files in /Volume1/DockerData/containers/container id.
Again... about /Volume1/@apps/docker/conf/daemon.json: packaging this file along with the docker distribution implies loosing any customization at every upgrade. Am I wrong?
davidecavestro wrote: 13 Aug 2023, 20:38 Again...
Am I wrong?
This is the setting for the Docker app. After updating, it will be overwritten by the default configuration. It is not recommended that you modify it. If you insist, you may need to backup and modify it frequently.
davidecavestro
TMzethar wrote: 14 Aug 2023, 19:10
Am I wrong?
I see... so I assume the only option to control logs for the whole docker daemon is setting the Log Retention through Docker Manager user interface. Then any customized log option (i.e. changing the driver) should be set on a per-container basis.
Return to “Docker”
