TOS 5.0.157 (x.86) is Released for Update
kenfrog
Re: TOS 5.0.157 (x.86) is Released for Update
Post by kenfrog »
I too only see one set of data for all but exporting the data for each selected disk get the correct info. So, GUI is only looking at the selected first target and not the user selected target.
SSH Console and the data matched fine. the gui script will need to be told to select the correct disk from the array. OR check the SSH shell console :)
data from the export
Disk 1 : Good No abnormalities were detected on this hard drive.
ID Attribute Value Worst Threshold Raw data
1 Raw_Read_Error_Rate 82 64 44 144462646
2 Spin_Up_Time 95 94 0 0
3 Start_Stop_Count 100 100 20 54
4 Reallocated_Sector_Ct 100 100 10 0
5 Seek_Error_Rate 83 60 45 218380353
6 Power_On_Hours 92 92 0 7442
Disk 2 : Good No abnormalities were detected on this hard drive.
1 Raw_Read_Error_Rate 81 64 44 127034201
2 Spin_Up_Time 94 93 0 0
5 Seek_Error_Rate 83 60 45 217726002
Disk 3: Good No abnormalities were detected on this hard drive.
1 Raw_Read_Error_Rate 74 64 44 25172118
2 Spin_Up_Time 96 92 0 0
3 Start_Stop_Count 100 100 20 49
5 Seek_Error_Rate 83 60 45 212650637
I think its a simple code change or mistake on the script to select the correct target disk/device : )
This issue will be fixed in the next version.
MisterXY
Germany
Post by MisterXY »
@TMSupport
do you also fixed the permission error with usbshare2?
scout71
Italy
Post by scout71 »
From today I can no longer access TOS with this OS version installed. I can access the installed apps (Jellyfin, SyncThing, etc ...) but not the TOS web interface. I tried to reboot and I also got the system warning mail that it had rebooted abnormally so it is running correctly. What can it be? I haven't changed anything from yesterday to today (F2-221)
scout71
Italy
Post by scout71 »
I forgot to say that the ping gives me a positive result, the server is reachable.
{L_BUTTON_AT}scout71
Obviously, the one web service does not start properly, or it may be corrupt. Did you uninstall any app recently?
For now, you need to reinstall your TOS.
scout71
Italy
Post by scout71 »
Damn, what bad luck! I haven't installed or uninstalled anything recently, however I try to reinstall TOS. Thanks for the reply!
Righty01
Post by Righty01 »
installed TOS 5 and had problems with my 4 Ethernet ports. I can get 1 working then expand it 2 then so on . when we get to the 3rd or 4th I cannot see my Nas or type in ip address nothing . I have made all ports as a static so they don't change. Once I unplug and go back to 1 port it works. very frustrating. Check cables and replaced with brand new. I can use any port as a single connection .
F5-421 MODEL
{L_BUTTON_AT}Righty01
Sorry, it is not so clear. How did you expand your four ports? did you connect them all to the router ports? or made a link aggregation group???
Righty01
Post by Righty01 »
All sorted out Thank you
