NFS service issues at NAS startup
macmpi
Re: NFS service issues at NAS startup
Post by macmpi »
any update on this issue?
Suggestion on a workaround?
According to the results here, NFS service should be re-enabled after TNAS is rebooted to allow the clients to be connected. Sorry for all the troubles.
macmpi
Post by macmpi »
Thanks for feedback.
So, this qualifies as a bug, right?
(can't think this could be a feature for a server: all those services should be available at boot if previously activated).
Hope this will be in good standing on priority list for fixes in an soon-to-be release.
Would you have any expected timeline for this fix please?
Thanks.
Hi macmpi,
You got the point wrong here. Normally NFS NAS server will not reconnect to NFS client after reboot, as the server couldn't remember the connection, and server is to be connected, not to connect with client. So you need to find a NFS client software which owns feature to reconnect with the server
automatically after server reboot. I hope you can get my point now.
macmpi
Post by macmpi »
Hi TMRoy,
I think you got the symptom wrong!
There is no way a client can NFS connect to TNAS if TNAS does NOT run the service after boot!
So what needs to be fixed is that TNAS launches the NFS service at reboot (if previously enabled of course), as it does for all other file service (SMB, AFP)
So the issue is 100% on TNAS side.
I hope this is well understood.
Thanks.
macmpi
Post by macmpi »
TMroy wrote: ↑15 Apr 2020, 23:09
on TNAS:
ls -la /etc/rc.d/
total 8
drwxr-xr-x  2 root root 4096 Mar 19 08:29 .
drwxr-xr-x 59 root root 4096 Apr 22 16:01 ..
lrwxrwxrwx  1 root root   24 Mar 19 08:29 K00rtk-supplicant -> ../init.d/rtk-supplicant
lrwxrwxrwx  1 root root   17 Mar 19 08:29 K00xeninit -> ../init.d/xeninit
lrwxrwxrwx  1 root root   13 Mar 19 08:29 K100shutdn -> ../init.d/rcK
lrwxrwxrwx  1 root root   15 Mar 19 08:29 K10rsync -> ../init.d/rsync
lrwxrwxrwx  1 root root   14 Mar 19 08:29 K50sshd -> ../init.d/sshd
lrwxrwxrwx  1 root root   17 Mar 19 08:29 K90network -> ../init.d/network
lrwxrwxrwx  1 root root   20 Mar 19 08:29 K90sysfixtime -> ../init.d/sysfixtime
lrwxrwxrwx  1 root root   14 Mar 19 08:29 K98boot -> ../init.d/boot
lrwxrwxrwx  1 root root   13 Mar 19 08:29 K99shutdn -> ../init.d/rcK
lrwxrwxrwx  1 root root   16 Mar 19 08:29 K99umount -> ../init.d/umount
lrwxrwxrwx  1 root root   20 Mar 19 08:29 S00sysfixtime -> ../init.d/sysfixtime
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S05xeninit -> ../init.d/xeninit
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S09realtek -> ../init.d/realtek
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S10boot -> ../init.d/boot
lrwxrwxrwx  1 root root   16 Mar 19 08:29 S10system -> ../init.d/system
lrwxrwxrwx  1 root root   20 Mar 19 08:29 S11syscontrol -> ../init.d/syscontrol
lrwxrwxrwx  1 root root   16 Mar 19 08:29 S11sysctl -> ../init.d/sysctl
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S12rpcd -> ../init.d/rpcd
lrwxrwxrwx  1 root root   13 Mar 19 08:29 S13led -> ../init.d/led
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S15lvm2 -> ../init.d/lvm2
lrwxrwxrwx  1 root root   20 Mar 19 08:29 S19btrfs-scan -> ../init.d/btrfs-scan
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S20network -> ../init.d/network
lrwxrwxrwx  1 root root   18 Mar 19 08:29 S30mountusb -> ../init.d/mountusb
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S50cron -> ../init.d/cron
lrwxrwxrwx  1 root root   15 Mar 19 08:29 S50nginx -> ../init.d/nginx
lrwxrwxrwx  1 root root   18 Mar 19 08:29 S50php7-fpm -> ../init.d/php7-fpm
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S60dbus -> ../init.d/dbus
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S60krb5kdc -> ../init.d/krb5kdc
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S60ntpdate -> ../init.d/ntpdate
lrwxrwxrwx  1 root root   22 Mar 19 08:29 S61avahi-daemon -> ../init.d/avahi-daemon
lrwxrwxrwx  1 root root   22 Mar 19 08:29 S93triggerhappy -> ../init.d/triggerhappy
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S95done -> ../init.d/done
lrwxrwxrwx  1 root root   16 Mar 19 08:29 S95smartd -> ../init.d/smartd
lrwxrwxrwx  1 root root   14 Mar 19 08:29 S95wsdd -> ../init.d/wsdd
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S98sysntpd -> ../init.d/sysntpd
lrwxrwxrwx  1 root root   24 Mar 19 08:29 S99rtk-supplicant -> ../init.d/rtk-supplicant
lrwxrwxrwx  1 root root   17 Mar 19 08:29 S99tosboot -> ../init.d/tosboot
so it turn-out that indeed there is no reference to
/etc/init.d/nfs
so nfs is NOT slated to start at TNAS startup...
got to root (su -) and:
 ./etc/init.d/nfs restart
Shutting down NFS mountd: OK
Shutting down NFS daemon: OK
Shutting down NFS services: OK
Stopping NFS statd: OK
Stopping rpcbind daemon: OK
Starting rpcbind: OK
Starting NFS statd: OK
Starting NFS mountd: OK
Starting NFS daemon: rpc.idmapd: Could not find group "nobody"
(BTW note the reported error) And now I can connect with my client: so, again, service was not started by TNAS at boot.
Then the final touch:
./etc/init.d/nfs enable
ls -la /etc/rc.d/
lrwxrwxrwx  1 root root   13 Apr 22 23:08 S60nfs -> ../init.d/nfs
I then restart the TNAS and... guess what?... Now nfs service starts at TNAS reboot.
Would be nice if this service is really enabled with the UI: currently the UI says it is enabled, but IS_NOT.
Now I imagine your team can easily fix it?
Thanks for prompt consideration.
OK, thanks a lot! will check it soon and come back to you.
psor
Post by psor »
Nice work, I was experimenting the same problem.
Hi macmpi,
We have tested here. the issue you mentioned did not happen here. NFS service was checked and enabled both at front-end and back-end.
macmpi
Post by macmpi »
TMSupport wrote: ↑24 Apr 2020, 17:40We have tested here. the issue you mentioned did not happen here.
Can you be more specific on TNAS models and SW releases?
See my config in signature.
I'm afraid, I'm not alone with this problem (see @psor for instance).
Maybe it's an older release big that got propagated with firmware updates, or sth.
Anyway, I have it on a standard install for sure...
Return to “File Services”
