Update Https Certificate on TOS 5
dianzisongyang
Japan
Re: Update Https Certificate on TOS 5
Post by dianzisongyang »
{L_BUTTON_AT}dianzisongyang
TMzethar wrote: ↑18 Jan 2024, 18:59 If you are referring to TOS's HTTPS SSL certificate, please refer to this to update them: viewtopic.php?f=78&t=4243 If you want to customize the certificate, this feature is currently not supported.
If I use https:// then I get error and warning. I want to use it and disable http:// How do I enable https:// with no errors?
Instead of using HTTP, you can go to the Network General module in the Control panel and enable "Force redirection from HTTP connections to HTTPS connections". If you want to configure your domain's certificate to make HTTPS access appear secure, You need to wait for us to release TOS 6.
coolnest
Vietnam
Post by coolnest »
ssh into your nas and go to /etc/nginx/nginx.conf
You can configure your certificate there
Return to “Security”
