TOS 5.0.128 (x.86) is Released for Update
FatherOfMayhem
Re: TOS 5.0.128 (x.86) is Released for Update
Post by FatherOfMayhem »
maxmatech wrote:
Same with my device - Available but interface not
Regarding the prompt "the website is not available", "192.168.1.90 rejected the connection" when you access TOS, can you post a screenshot?
FatherOfMayhem
THIS IS THE SCREEN - https://ibb.co/hDbSfqv
Did you search again your tnas with the TNAS PC for windows or for mac? is the IP address shown correct? Please make sure that your IP address is correct.
joka388
Austria
Post by joka388 »
> correct.
In my case the IP Adress is correct 192.168.1.90. The access with SMB works fine, but no interface in Chrome, or another browser.
May I have a look what address showing in the address bar?
joka388
Austria
Post by joka388 »
In Fing Network Scanner i see https://ibb.co/jrSJLpk
joka388
Austria
Post by joka388 »
This one https://ibb.co/NNsbCp7
Thank you!
From your screenshot we may know one or more system files were lost or corrupt during your update. But at this moment, we do not know what causes this issue, we need to look deeper into this issue. But one more question, what was the first TOS 5.0 version you installed? did you ever install a beta version?
Now, to recover the corrupt system file, you may need to reinstall the 5.0.125, then try again to update to 5.0.128.
You can download the 5.0.125 from here.
And follow this instruction method 2 to reinstall the TOS. We apologize for the issue happening now. After the reinstallation, you do not need to reinstall your app, you can re-enable them from app store.
joka388
Austria
Post by joka388 »
TMroy wrote:
> Thank you!
> beta version?
Yes, first i use the beta version an than i installed 5.0.125 and the following updates.
