USB Access via SMB TOS 4.39
rocketron51
Re: USB Access via SMB TOS 4.39
Post by rocketron51 »
@TMroy
Are you saying that your tech or software staff cannot replicate what is happening on my F5-221.
BTW the "Corrupted Volume" is happening on Bay 2 to Bay 5 and if you have more than 2 drives installed e.g.
Bay 1 = drive OK, Bay 2 = drive OK, Bay 3 = drive Volume Corrupted
move drive in Bay 2 to Bay 3 or Bay 4 or Bay 5
any drive that is placed in an empty bay then gets Volume Corrupted
All drives in all bays work perfectly under TOS 4.2.39
Did you set any RAID configuration for these 5 drives? or 5 drives just keep single and every drive has its own volume?
rocketron51
@TMroy
No raid config all 5 drives are single and every drive has its own volume
Thank you!
We will verify it in the lab. If we need any help, I will let you know.
rocketron51
@TMroy
Thank you, I look forward to this problem being solved, meanwhile I have had to revert back to TOS 4.2.39.
rocketron51
@TMroy
Forgot to mention that all Volumes are EXT4
