Configuration Recommendations for Hyper Cache
Newbie98000
Re: Configuration Recommendations for Hyper Cache
Post by Newbie98000 »
To precise a bit more
Nas to use f2-223 with 4 Go Ram
RAID 1 with 2 To mechanic Harddisk to use regularly :
- Homeo Assistant for home automation running Under Docker (maybe 2 or 3 VMs Max)
- smb Server for bureautic and mp3 use
- 2 Gbe : one dedicated to domotic Matter + Thread VLAN, one dedicated to Internet
- Cloud Backup to Cloud Services Aws etc.
Cache m2 to accelerate RW Performance : here is my question, which is the minimum configuration in my use case, though I don't want to use m2 drives to store anything but Cache files
Hope this helps
manya2000
Post by manya2000 »
I have a F2-423 with:
32 GB RAM
2 X Western Digital 6TB WD Red Plus NAS Internal Hard Drive HDD - 5400 RPM, SATA 6 Gb/s, CMR, 256 MB Cache using TRAID
If I am correct, the F2-423 uses Pci Express 3.0 X1.
Can I install a Crucial P3 Ct1000p3ssd8 1 Tb Solid State Drive - M.2 2280 Internal - Pci Express Nvme (pci Express Nvme 3.0 X4) since I can find a 3.0X1 at a reasonable price.
Can I install just 1 SSD or do I have to install 2 SSD?
What is the advantage of installing 2 instead of 1 if I only backup photos and camera videos and only use Jellyfin and Terra Photo.
Don't you know how much capacity Hyper Cache you should use?
You can try using one first. Add a second one when you think it's necessary.
darkside501st
Re: Configuration Recommendations for SSD Cache
Post by darkside501st »
This is a confusing thread. I came here to look for answers on what type/size of m.2 drives I should get to best take advantage of the caching feature on the new F4-424 Pro NAS that I just got, which has 32Gb of ram. I didn't see any info on the product pages. I did find a compatibility list but that is not suggestions or recommendations for how to properly select the right m.2 for your NAS or for your needs. I contacted the TerraMaster Helpdesk but they didn't have any information and suggested a Google search.
lsoto wrote: 19 May 2023, 19:07 T6-423 bought yesterday. I had added 2 x Samsung 970 EVO Plus 2Tb.
First: at installation time it offered me create the pool along the other four HD that I installed for previous nas. Does Tos 5 have tiered storage? Otherwise it is a bit strange and not useful mixing HDD with SSD, isn't it?
Second: The Samsung were at 60C degrees before using it (formatting yet). They are currently at 83C while the sync at Hyper Cache creation (raid-1). Could/Should be a heatsink added to them? How should be the specs size wise?
Third: With the factory 4Gb (onboard?) RAM, it only let me create a 288Gb (not 320Gb) HyperCache (raid-1, read/write). It let me put a bigger size but discard it.
And the worst of everything it is that I saw this post AFTER having bought the NAS and the NVMe SSD. I didn't saw anything about this on the product page.
It is going to be at first my secondary storage (and probably add a secondary D6-320 in the future), so I didn't plan to activate almost any application, but just use it as a file server. And thus I didn't intend to upgrade the RAM, but it looks like that I will need to go for even the 16Gb SODIMM one...
So, if I understand you correctly you got two 2Tb m.2 drives for caching (4Tb total) and the TOS system limited your cache to 288Gb total. You said that the T6-423 comes with 4Gb of ram. So that is 1:72 ratio. For every 1gb ram there is 72gb cache. I wonder if that is the same for all the various models.
Can anyone else chime in to confirm that the TOS system limits the cache and what your cache size is compared to your ram?
It looks like of all the m.2 drives on the compatibility list I see 1Tb and then 2Tb with nothing in between. According to the first post (ignoring the confusing paragraph and just looking at the chart), if I have 32Gb of ram then I should get a total cache of 3200Gb or 3.2Tb. So since there is no 1.6Tb drive should I go with two 1Tb drives and limit my cache to 2Tb (2000Gb) or should I go with two 2Tb and then will the system limit my cache to 3.2Tb (3200Gb) and not make use of the remaining 800Gb available?
Romario
Post by Romario »
SSD cache is not worth the suffering. If you don't work with a lot of small files, then you don't need it. I can send a link to the tests (but there is Russian). My experience (initial conclusions) about using the cache is negative. TOS stopped loading 2 times after the cache was assigned (wrote /var/run/TOSDaemon.pid: No such file or directory). Now everything seems to be working fine with the cache disabled.
ORION
Post by ORION »
we Russians have already understood one simple truth about the cache and from here we can conclude: SSD cache is needed only for virtual machines and ISCSI LUNs. For home or non-demanding virtual machines, this is an extra risk of data loss and an unnecessary waste of money. But it is still very pleasant to have such an opportunity than not to have it. In addition, in TOS, instead of an SSD cache, you can make a pool and volume directly on SSD M2 disks. Good luck.
F4-424 Pro :roll:
F2-210 :D
Lau6311
Malaysia
Post by Lau6311 »
After a simple search, understand that hyper cache is usually "not so effective" for general light users.
It is the desire of many users wanting speedy response of nas and happy that hyper cache is available.
So I will remove the 2 NVME SSD from nas now for other better uses in my PC and as an external fast NVME SSD drive.
F2-223, TOS 6.0.648, 2x8T N300 HDD Vol 1 & 3 (Singles)
1x1T Kingston NVME SSD Vol 2 (Single)
1x256G Hynix NVME SSD Hyper Cache (Balance Mode, 238G)
32G RAM
Herewerare2024
Post by Herewerare2024 »
I've found the nvme drive is great to host the applications and various databases associated. I installed tos on the nvme and then created a volume from the remaining free space. I used the nvme based volume for applications. Worked very well and relatively simple to configure as such.
facemir
Australia
Post by facemir »
F4-425 Plus. Is there room to use a NVMe with heatsink on this ??
The heat sink thickness should not exceed 3mm.
