Copy to external USB 4.2.30 Broken!!
capnhowyoudo
Re: Copy to external USB 4.2.30 Broken!!
Post by capnhowyoudo »
Has this now been identified as an issue and is a fix in the works?
TNAS F4-210
TOS 4.2.43-2203011629
4X WD Red Plus 8TB (RAID5)
Hardfecx
Post by Hardfecx »
did you all tried tro restart the nas once and unplug and replug the HDD's?
capnhowyoudo
Hardfecx wrote: ↑10 Mar 2022, 00:22 did you all tried tro restart the nas once and unplug and replug the HDD's?
I have.
TNAS F4-210
joka388
Austria
Post by joka388 »
capnhowyoudo wrote: ↑10 Mar 2022, 00:42
I have.
I also
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
We have verified it on F2-210 and F4-210, using smb service to access, and transferring large files over 5G to usb devices, the results are normal.
According to your screenshot, it shows "Error 0x8007003B", you can try to search for the solution of this error on Google.
V8Triker
Post by V8Triker »
TMSupport wrote: ↑10 Mar 2022, 18:25 We have verified it on F2-210 and F4-210, using smb service to access, and transferring large files over 5G to usb devices, the results are normal.
I have also undertaken further testing on my F5-221
I can copy a 3.5GB file to/from TNAS to USB, also to/from Windows (SMB) and Macbook (AFP).
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
{L_BUTTON_AT}capnhowyoudo
Does this help? https://answers.microsoft.com/en-us/win ... 7154ace974 With your IT experience I am sure you wouldn't have forgotten about the file size limitation on FAT32, anyway read the link and let us know if you solve it. I tested with an F2-422 (TOS 5.0) and WD MyBook (6TB RAID 0) and it worked with no issues with a few 60GB MKV files. (Mac and PC) Good luck
capnhowyoudo
Charlie_Croker wrote: ↑11 Mar 2022, 01:24 Does this help? https://answers.microsoft.com/en-us/win ... 7154ace974 With your IT experience I am sure you wouldn't have forgotten about the file size limitation on FAT32, anyway read the link and let us know if you solve it. I tested with an F2-422 (TOS 5.0) and WD MyBook (6TB RAID 0) and it worked with no issues with a few 60GB MKV files. (Mac and PC) Good luck
Thanks for the info all of these steps have been tired. I have not forgotten the size limitation. Both drives are NTFS. As i stated previously. this was all working for around 2 years before this update. I have conducted further testing reset the device back to factory settings and put on older firmware. this is still not working with Windows file transfer or robocopy to \\ip\usbshare1 or usbsahre2. This will however work when not copyi8ng to the attached usb for example a folder created on the TNAS local storage. I did however restore my configuration from a backup perhaps something in there is still corrupt idk. I have tried transferring files from a linux machine to the usb share and that seems to be working with no errors. i have removed all recent updates from my 4 windows machines going all the way back to Jan but robocoy and drag and drop to \\ip\usbshare still does not work. I have disabled FW and AV still no luck. im getting fed up at this point.
TNAS F4-210
If convenient, you can contact our tech team to help troubleshoot the issue.
Charlie_Croker
Saudi Arabia
It is a strange thing, if its working via Linux, it could be down to a windows update?
