After 4.2.30 update TOS machines disappear from network
Re: After 4.2.30 update TOS machines disappear from network
You can check permissions for users, user groups, and shared folders, then disconnect the mapping, clear the cache, and remap.
Not working with SMB: viewtopic.php?f=77&t=2759
joka388
Austria
Post by joka388 »
I have tried all of these but it is the same as before.
With the old firmware 4.2.28 all works fine, since 4.20.30 i can´t rename any folder.
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
To modify the shared folder name, you can go to the TOS control panel.
The subfolder name cannot be modified. You can select the shared folder in the TOS file management after giving the user read and write permissions, right-click to select Properties, and then set the permissions. When setting permissions, check once to inherit the permissions of the shared folder to All subfolders.
joka388
Austria
Post by joka388 »
I have read/write permissons an all Folders and i can rename the folders within TOS Mediamanager but not with Windows Explorer.
With Windows Explorer i get this Errormassage.
UncleJohnsBand
Post by UncleJohnsBand »
As far as USB access from Windows I have this long standing gripe which is the only access to USB drives is by the admin account. You cannot change user access to Guest or specific users.
They continue to say they will "get to it" but you can see how long this has been open and every update I check and every update no change....
viewtopic.php?f=25&t=264
{L_BUTTON_AT}UncleJohnsBand
In TOS 5, you can edit permissions of USB devices.
joka388 wrote: ↑09 Mar 2022, 01:20 I have read/write permissons an all Folders and i can rename the folders within TOS Mediamanager but not with Windows Explorer.
Please contact our tech team to help troubleshoot remotely.
UncleJohnsBand
TMSupport wrote: ↑09 Mar 2022, 17:13 In TOS 5, you can edit permissions of USB devices.
Thanks.... That's great news.... How long till general release of TOS 5?
joebandit
Post by joebandit »
my 2 f4-210s now show error 502 bad gateway
You still need to wait for months.
Return to “System Update”
