TOS 4.2.28(X86) is released for update
yak983
Re: TOS 4.2.28 is released for update!
Post by yak983 »
now it's 100% safe?
Saijin_Naib
Post by Saijin_Naib »
{L_BUTTON_AT}TMSupport
Thanks for this patch, and for making it timely.
Unfortunately, it seems all the ARM series are still vulnerable, so my unit remains powered off still until such patch is released for the ARM series.
Do you know if that will be this week?
rightLANE
Post by rightLANE »
I ended up installing this update sooner than I normally do due to the security concerns with not upgrading. First off, it is nice to see the update work through the TOS dashboard rather than having to manually update. Previous versions may have had this option working, but this was the first time I noticed so kudos for that.
As usual, the UPS setting reset to ‘shutdown after 7 seconds’ as opposed to ‘on low battery’ which I had it set to, but I was expecting that. Same with the Bonjour discovery service turning on.
Plex and Emby continue to function as normal. I skipped the versions which had issues, so I never ran into problems others had reported, but it’s always good to see both working as expected.
I’d been running my fan on low as I was running into fan issues with the smart fan setting. Previously, on low, my fan was constantly running in the ~900rpm range and the HDDs were going to sleep as expected. I just changed to smart fan and it seems to work correctly. The fan went from 10rpm to ~1000 once the CPU temp rose. I’ll have to report back later if the HDDs sleep once my NAS has been running longer.
F2-221 2x 10TB Exos X14
UncleJohnsBand
Post by UncleJohnsBand »
All loaded..... Had to download and then update... i.e. The online update still does not work.
Had to again set my Workgroup name... Never seems to retain that info.
Other than that everything is fine for now.
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
Installed, didnt auto update (probably as I had locked it down so much). So went to TM website and downloaded from Support/Downloads (in case anyone else is looking for it).
Installed OK, although as I watched the update (Hey, I'm a boring guy), I noted the top of the status flag flash (Where it normally says and was saying "GOOD - TNAS is operating effectively" it was orange with "TNAS is Vulnerable".
Anyway, with the limited release notes I am hoping this will have mitigated against the worst vulnerabilities, but can I add my voice to the one asking for proper release notes, listing any vulnerabilities that have been closed, in this kind of format https://i.stack.imgur.com/JDzK2.jpg
So those of us who check Zero days etc can ascertain whether we are patched or need to take action.
psikic
Post by psikic »
I installed this update and went from 4.2.18 to 4.2.28. Now I can no longer access TOS. The main page gives a HTTP 200 OK after several minutes but the page that comes up is completely blank. TOS works for about 30 seconds after boot until something gets loaded and crashes. SMB file shares don't work either, because I don't think it gets that far in the boot process.
When I run dmesg, I see several crashes, which make it look like one of the kernel modules is killing the system. Virtualbox?
[ 536.097374] vboxdrv: Found 4 processor cores
[ 536.115590] vboxdrv: TSC mode is Invariant, tentative frequency 1497599353 Hz
[ 536.118102] vboxdrv: Successfully loaded version 6.1.26 r145957 (interface 0x00300000)
[ 536.123687] VBoxNetAdp: Successfully started.
[ 536.195592] VBoxNetFlt: Successfully started.
[ 542.144473] BUG: unable to handle kernel paging request at 000007d8000007d8
[ 542.146104] PGD 0 P4D 0
[ 542.147689] Oops: 0002 [#1] SMP PTI
[ 542.149249] CPU: 3 PID: 9690 Comm: nspr-2 Tainted: G O 4.19.165+ #322
[ 542.150837] Hardware name: retsamarret 000-F5422-FBA001-0001/TM-J3455-4G3L, BIOS MAPL0301V06 07/29/2019
[ 542.152466] RIP: 0010:mutex_lock+0x18/0x30
[ 542.154078] Code: 00 00 55 be 02 00 00 00 48 89 e5 e8 42 fb ff ff 5d c3 55 48 89 e5 53 48 89 fb e8 33 e8 ff ff 65 48 8b 14 25 40 4d 01 00 31 c0 <f0> 48 0f b1 13 75 03 5b 5d c3 48 89 df e8 c6 ff ff ff 5b 5d c3 0f
[ 542.155831] RSP: 0018:ffffaad8c133be38 EFLAGS: 00010246
[ 542.157592] RAX: 0000000000000000 RBX: 000007d8000007d8 RCX: ffffffffc06064a0
[ 542.159390] RDX: ffff9e6eb294ec00 RSI: 0000000000000008 RDI: 000007d8000007d8
[ 542.161177] RBP: ffffaad8c133be40 R08: 0000000000000000 R09: 0000000000000000
[ 542.162970] R10: ffffaad8c133be80 R11: ffff9e6eb4702210 R12: 000007d8000007d8
[ 542.164761] R13: ffff9e6d91df17b8 R14: ffff9e6eb47022c8 R15: ffff9e6d9d56eb40
[ 542.166559] FS: 00007ff631413700(0000) GS:ffff9e6eb7b80000(0000) knlGS:0000000000000000
[ 542.168381] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 542.170191] CR2: 000007d8000007d8 CR3: 0000000144dc8000 CR4: 00000000003406e0
[ 542.172020] Call Trace:
[ 542.173840] eventpoll_release_file+0x40/0x80
[ 542.175656] __fput+0x1aa/0x1e0
[ 542.177461] ____fput+0x9/0x10
[ 542.179221] task_work_run+0x89/0xb0
[ 542.180968] exit_to_usermode_loop+0x95/0xa0
[ 542.182713] do_syscall_64+0xf0/0x100
[ 542.184453] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 542.186194] RIP: 0033:0x7ff630e8899c
[ 542.187912] Code: 0f 05 48 3d 00 f0 ff ff 77 44 f3 c3 66 90 48 83 ec 18 48 89 7c 24 08 e8 22 fc ff ff 48 8b 7c 24 08 89 c2 b8 03 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 2e 89 d7 89 44 24 08 e8 61 fc ff ff 8b 44 24
[ 542.189771] RSP: 002b:00007ff6314119f0 EFLAGS: 00000293 ORIG_RAX: 0000000000000003
[ 542.191638] RAX: 0000000000000000 RBX: 00007ff630e6dee8 RCX: 00007ff630e8899c
[ 542.193532] RDX: 0000000000000000 RSI: 00000000c01c569a RDI: 000000000000000d
[ 542.195384] RBP: 00007ff631411a20 R08: 0000000000000000 R09: 00007ff620000048
[ 542.197242] R10: 0000000000000a37 R11: 0000000000000293 R12: 0000000000000000
[ 542.199074] R13: 00007ff620000f30 R14: 0000000000000020 R15: 0000000000000007
[ 542.200879] Modules linked in: vboxnetflt(O) vboxnetadp(O) vboxdrv(O) flashcache(O) led_drv_TMJ33(O) aqc113 rtl8822bu(O) 8812au(O)
[ 542.202741] CR2: 000007d8000007d8
[ 542.204593] ---[ end trace 14d7b0999d04479e ]---
[ 542.206450] RIP: 0010:mutex_lock+0x18/0x30
[ 542.208283] Code: 00 00 55 be 02 00 00 00 48 89 e5 e8 42 fb ff ff 5d c3 55 48 89 e5 53 48 89 fb e8 33 e8 ff ff 65 48 8b 14 25 40 4d 01 00 31 c0 <f0> 48 0f b1 13 75 03 5b 5d c3 48 89 df e8 c6 ff ff ff 5b 5d c3 0f
[ 542.210266] RSP: 0018:ffffaad8c133be38 EFLAGS: 00010246
[ 542.212252] RAX: 0000000000000000 RBX: 000007d8000007d8 RCX: ffffffffc06064a0
[ 542.214272] RDX: ffff9e6eb294ec00 RSI: 0000000000000008 RDI: 000007d8000007d8
[ 542.216280] RBP: ffffaad8c133be40 R08: 0000000000000000 R09: 0000000000000000
[ 542.218279] R10: ffffaad8c133be80 R11: ffff9e6eb4702210 R12: 000007d8000007d8
[ 542.220278] R13: ffff9e6d91df17b8 R14: ffff9e6eb47022c8 R15: ffff9e6d9d56eb40
[ 542.222252] FS: 00007ff631413700(0000) GS:ffff9e6eb7b80000(0000) knlGS:0000000000000000
[ 542.224222] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 542.226219] CR2: 000007d8000007d8 CR3: 0000000144dc8000 CR4: 00000000003406e0
psikic
Post by psikic »
If I could figure out how to uninstall virtualbox from the command line, I'd try that.
alesor
Post by alesor »
Every time I update TOS to the latest version, the "Web Server" application no longer works and from SSH I have to execute the following instruction:
cp /mnt/md0/application/WebServer/libdb-5.3.so /mnt/md0/application/lib/libdb-5.3.so
Besides that, I have to edit the http.conf file every time to fix "DocumentRoot" because it is not updated by the application.
Is it possible to fix the problem in the next versions?
{L_BUTTON_AT}alesor
Hi! We have received your feedback and will verify it soon.
{L_BUTTON_AT}psikic
After verification we found that TOS 4.2.28 is not compatible with VirtualBox app. It is recommended that you reinstall the TOS 4.2.18 if you use VirtualBox.
