@V8Triker,
When you moved from using Plex as a "normal" TOS application to using it inside Docker did you lose your Plex database?? I understand that all the movies, TV shows, etc. files would not be touched but were you able to retain all of the metadata for your media or were you forced to rebuild the database from scratch??
If not is anyone aware of how to retain the metadata when transferring Plex to a Docker container?
Thanks . .
Plex in Docker?? - Please Help
- Gandalf1369
Re: Plex in Docker?? - Please Help
[at=Gandalf1369 post_id=15368 time=1640523480 user_id=1631][/at]
I did the Docker Plex as a clean, base, install.
It will not use the existing Plex metadata, as it is totally separate. I had to scan all the films in, and make the adjustments.
You have me wondering if it is possible to share the metatdata between two installs.
Could be a job for tomorrow morning
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
TNAS F5-221
1X WD 4TB USB
{L_BUTTON_AT}sports_wook
Since I finally decided to register, I thought I would take a minute to say *thank you* for the post you kindly shared here:
viewtopic.php?f=51&t=2236
I plan on taking advantage of your wonderful write up in the coming days. (Just need to get a bit more familiar with Docker first.)F2-220 (x86 flavored!)
