Hello! Thanks for your answer .
I have followed your advice and although with fear I completed the assistant WITHOUT data loss.
So eternally grateful.
But now
We continue with the Chapters of "File X"
After updating as "powerq" told me.
I can't install any new app.
nor upgrade the two that had installed "ARIA" and "CLAMAV"
Every time I try to install or update the process, it stays at 50% download and is eternally so.
As if it were read only.
And also I cannot activate the SMB / CIFS Protocol.
when I activate it and save the configuration, but it says that everything ok "your configuration has been saved" but in checkbox it is unchecked again and the service is not activated.
There is a video of whats happening ...
Any Idea ?
https://www.dropbox.com/sh/udpu58prr4xl ... .webm?dl=0
