3rd party app request and work in progress
Re: 3rd party app request and work in progress
PHP 8.1 work in progress
yeweimei
Post by yeweimei »
filerun is get update on their official website.please update,thanks :mrgreen:
We'll do it :D, let's try to keep this for new app requests
Roccia7
Italy
Post by Roccia7 »
Hello outkastm, is it possile to have calibre?
https://calibre-ebook.com/
TNAS F2-220
TOS 5.0.176
psikic
Post by psikic »
There is an awesome docker container that contains calibre and you can use an RDP client to see the GUI. It runs great on docker on the TNAS.
https://hub.docker.com/r/linuxserver/calibre
Roccia7 wrote: 21 Dec 2021, 05:17 Hello outkastm, is it possile to have calibre?
Roccia7
Italy
Post by Roccia7 »
psikic wrote: 22 Dec 2021, 02:30 There is an awesome docker container that contains calibre and you can use an RDP client to see the GUI. It runs great on docker on the TNAS.
Thanks for your replay. Unfortunately i can't use docker. Every TOS update brocke my docker app and configuration, and till last update i also can't download any image from any source. So now i got tired use docker, and i would like, when possibile, use independent app
TNAS F2-220
TOS 5.0.176
yeweimei wrote: 21 Dec 2021, 00:20 filerun is get update on their official website.please update,thanks :mrgreen:
The app can be updated via internal update function
To install software updates please follow these steps:
  • Access your FileRun installation and log in as superuser (The default login name of the superuser is “admin” or “superuser”).
  • Open “Control Panel”
  • Go to “System configuration” » “Software update”
I'll have a look
RedCraft
Post by RedCraft »
Hi. Really need an application for arm processors, a two-panel file manager, like this: Midnight Commander, Krusader, MUCOMMANDER and so on...
Unfortunately, I could not find a program in the repository for this kind of work. And moving files from one hard drive to another hard drive requires a similar program, because the standard explorer is very inconvenient in displaying paths and selective relocation..
I found it, Midnight Commander but even though it says it's the arm version, it's not in the files. Really need this kind of 2-x panel file manager program.
Merry Christmas.
f2-210
added on the list
