VPN disconnected after some time
brunix86
Italy
Re: VPN disconnected after some time
Post by brunix86 »
{L_BUTTON_AT}TMSupport
Any news about my request?
(see my previous messages)
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1130 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
Hi!
This function will be fixed in the subsequent version.
iroiro
Post by iroiro »
I've been having similar VPN problems.
On OpenVPN connections after some time (hours) the connection stays listed as connected, but the "internet" line on the TNAS desktop dashboard says disconnected, if I disconnect the VPN or connect to a different VPN profile it reestablished the internet connection.
On L2TP connections I have the issue as mentioned in the original post.
iroiro
Post by iroiro »
TMSupport wrote: 12 Nov 2021, 22:08 Hi!
Can you confirm this has been addressed in 4.2.28?
iroiro wrote: 04 Feb 2022, 05:56
The issue has not been fixed in 4.2.28.
iroiro
Post by iroiro »
TMSupport wrote: 04 Feb 2022, 18:34
In which subsequent version will it be fixed?
Please pay attention to the forum update and wait patiently.
iroiro
Post by iroiro »
TMSupport wrote: 04 Feb 2022, 18:43 Please pay attention to the forum update and wait patiently.
We are waiting patiently and following the forum. Earlier you said it would be fixed in the subsequent version, the subsequent version did not contain the fix. It seems you are not delivering on your commitments.
brunix86
Italy
Post by brunix86 »
Hi, there are any news about this issue?
This problem still occurs.
Thanks.
My NAS Environment
  • TNAS F4-424
When using public IP to connect, if the public IP changes, the connection will be disconnected, and you need to use the new public IP to create a connection.
The option "Reconnect when VPN connection is lost" is available in TOS 5.
Return to “Network”
