RAID expansion
Bernhard.Wuest
Re: RAID expansion
Post by Bernhard.Wuest »
Another update.
I put the last 14TB disc in yesterday evening which finished an hour ago and the F5-420 went automatically in another repair cycle, at least I didn't du a thing.
Now the memory pool shows 29.1 TB used of 50.92 TB which means now after the last disc the system has adjusted to the new size.
If I go to the volume now the max button is not greyed out anymore and I could increase the volume to the full size of the space.
I just don't know it is advisable to do this will the synchronization is happening or if I should wait for the process to be finished and then to maximize the space.
Re: RAID expansion
{L_BUTTON_AT}Bernhard.Wuest
After RAID rebuilding is completed, add the capacity for your volume.
Bernhard.Wuest
Re: RAID expansion
Done. After the sync the expansion took seconds.
Now I have 50+ a little TB.
Thanks for helping
Case closed!
