[ rClonePlexDrive ] rsync for Cloud Storage + Plex Drive mount CLI
Re: [ rClonePlexDrive ][ 1.01.00 ] rsync for Cloud Storage + Plex Drive mount CLI
up to 1.01.00 (rclone up to 1.57.0)
Pavulon
Post by Pavulon »
outkastm wrote: 04 Jan 2022, 23:36 Added arm version
Just tested and it works great :)
Many thanks for this arm version 8-)
Is there any way to access SSH directly from NAS? ( not using putty)
Best wishes :)
F2-210
i'm not aware of any option to run a terminal directly from TOS.
But i will make soon available the app shellinabox, and you can run the terminal from any Web browser
viewtopic.php?f=37&t=2831&sid=fde68197c ... 4e87fcd84d
Pavulon
Post by Pavulon »
outkastm wrote: 06 Jan 2022, 03:38 i'm not aware of any option to run a terminal directly from TOS.
Great to hear :)
In that case I will have to wait :D
Thank you
F2-210
unixtall
Re: [ rClonePlexDrive ][ 1.02.00 ] rsync for Cloud Storage + Plex Drive mount CLI
Post by unixtall »
Could you put a tutorial to configure the folder and start synchronize de google drive? i have just only get created rclone.conf. What have i to do more?
there is already a complete tutorial on rclone website explaining how to connect the google drive
https://rclone.org/drive
make sure you always specify the complete path of rclone binary and the location of the config file.
See below an example
[root@TNAS-xxxx ~]# RCLONE=/usr/local/bin/rclone
[root@TNAS-xxxx ~]# CONFIG=/mnt/appdata/MOD_CONFIG/rClonePlexDrive/rclone/rclone.conf
#to initially create the config or adding providers, run below
#select [b]n[/b] for new remote and then [b]17[/b] for google drive
[root@TNAS-xxxx ~]# $RCLONE config --config=$CONFIG
Then to list the directory on the top level
[root@TNAS-xxxx ~]# $RCLONE --config=$CONFIG lsd remote:
To copy a local directory to a drive directory called backup
[root@TNAS-xxxx ~]# $RCLONE --config=$CONFIG copy /home/source remote:backup
Re: [ rClonePlexDrive ][ 1.04.00 ] rsync for Cloud Storage + Plex Drive mount CLI
up to 1.04.00 (rclone 1.59.0) and added TOS5 version
