TMSupport wrote: ↑09 Oct 2021, 18:03
Hi! Please check the running status of the docker service and JDownloader container.
I never had docker installed only the *.tpk file from the developer forum here. it worked until I installed the new TOS. I can't find how to return to 4.2.15 version, may youu help me?
Region and Language > time > still shows IST not GMT as set, Also Desktop shows IST not GMT
out of interest where are you based? in the UK we are still on BST (google also suggests IST can be used to denote Ireland Summer Time) which is GMT+1, rather than Indian Summer Time as that would mean it was GMT + 5.30
therefore the time zone is currently correct for me although would have been better to have BST not IST, my desktop shows the correct time and IST, being GMT would be incorrect as that would be an hour wrong, until the end of the month
so looking at my USB copy app, i set the time to 00:00 and then other are half an hour later.. but they seem to be runing 7 hours later than scheduled
Did you change the time zone after setting up the backup plan?
Maybe we can get the answer from tomorrow's backup results.
The JDdownloader is a third-party-develop app, we do not know if its configuration file has been stored in a correct location, its configuration may be overwritten during the system update. please try to install it again.
TMRyan wrote: ↑09 Oct 2021, 21:58
No I didn’t it’s always been set to gmt and usb copy was installed after the setup of my nas
Hardfecx wrote: ↑09 Oct 2021, 17:07
after Update, my JDownloader doesn't run anymore on my F4-210. It starts but I can't reach the webinterface saying "No connected JDownloader found"
Try to restar jdownloader from The configuration app, or check if your credential are correct in the configurato file
please look at my history as i have reported this also for well over a year but i just keep on getting the response that you can not find anything wrong
the backups take place at the correct time, but the report is wrong as it just doesnt make any sense, as you report that in this instance it started the task at 07:25 and finishes at 00:26, the actual start date is 00:25 and finishes at 00:26 i.e it takes a minute
i have watched my usb flash its activity light at the time so i know the backup is being done correctly
viewtopic.php?f=39&t=755
my understanding is that some how the time is being reported in chinese time i.e GMT +7 for the start time and the local time GMT +1 for the finish time
F2-424 TOS 7.0.1341 F2-423 TOS 7.0.1341 F2-210 TOS 4.2.44 D4-320
sianderson wrote: ↑10 Oct 2021, 01:55
To be honest I’m not that bothered as even at that time the NAS is not usually in use
