[ Traccar ] Free and open source modern GPS tracking system
Hardfecx
Re: [ Traccar ][ 4.14.0.0 ] Free and open source modern GPS tracking system
Post by Hardfecx »
I installed the newest Oracle Version but when i start the module, i get nothing... No new winwo...nothing?
What do I wrong?
You mean you get nothing on OracleJRE app WebUI or Traccar ?
For OracleJRE11 is normal, this app is just used as base for other apps, nothing to start for it. Just need to be installed.
Hardfecx
Post by Hardfecx »
I start Tracecar, in TOS, a Window opens where I can (as by JDownloader) start,/stop the module but after I get no Webinterface ("Website not available") and it's written that Tracecar Module is stopped.
Hardfecx
Post by Hardfecx »
I can choise to configure "Edittracar.xml" who's empty. In the Logfiles, i get this: "<br />
<b>Warning</b>: fopen(/mnt/appdata/MOD_CONFIG/Traccar/traccar.log): failed to open stream: No such file or directory in <b>/usr/www/modules/Traccar/www/6.php</b> on line <b>86</b><br />"
Check with FileBrowser within TOS if config file traccar.xml is located at
/mnt/appdata/MOD_CONFIG/Traccar/traccar.xml
Install also latest 4.14.0.1
Hardfecx
Post by Hardfecx »
In TOS 4.2.16 the xlm file was at the correct place.
Installed the newest version of Traccar and it work's now!
Thank you for your quick answer and modifications!
Hardfecx
Post by Hardfecx »
but i can'z edit the xml file via the app. I dont know if it is necessary?
Normally is not necessary, but you should be able to do it.
What you get when you go to Configuration files > edit traccar.xml like in the picture ?
Hardfecx
Post by Hardfecx »
I get a lot of text like on your screenshot. But this app is more complicated than I was expecting... I have a lot of trouble to get a signal from my GPS module in my Smartphone....
[/code]Is your phone Android?
Is very simple, you have to install Traccar client on your phone, setup the host file and on your router open the port 5055 to allow traccar client on your phone to comunicate with Traccar server.
As the text on config says, the parameters stop on this line
Config file end here!!! Below lines are example protocols
Rest of the lines are only protocol examples to add for different GPS devices
