[ Duplicati ] Store securely encrypted backups on cloud storage services!
Madvic
Spain
Re: [ Duplicati ] Store securely encrypted backups on cloud storage services!
Post by Madvic »
There is a folder MOD_CONFIG in Volume1, it has a subfolder "Duplicati" in it.
But it does not seem to be changed when I try to install the application, last mod date is yesterday when I first tried to install.
It seems a permission issue of /Volume1/MOD_CONFIG folder
Download again the app and install it, i made a small change
Also make sure you have the dependency apps installed : ModBase1 and mono
Madvic
Spain
Post by Madvic »
It is working now, I was missing "mono" dependency, my fault.
rapcat
Post by rapcat »
Hi, would we have an ARM version?
doctorase
Post by doctorase »
Hi! It's better this tool than default duple backup?
brandria
Post by brandria »
Hi @outkastm thanks for you work. I just have a question, i just tried to install your duplicati app after I have installed modbase1 and mono. The app seems to start and then stop without any warning. I do not see any Duplicati folder inside my MOD_CONFIG folder. Can you help me ? Thanks
I am with TOS 5.1.31-00348
i have to ceck the start script function with latest TOS version
bradl822
Post by bradl822 »
I have had this happen with a few random apps. It has nearly always been that I excited to soon after install.
To fix open Applications>All find the app that won't launch. Select uninstall. Click to remove all configuration. Once this is done, reinstall but wait another minute after it finishes. This solves it for me!
Only other time I have had this, it was due to not being fully up to date with mono or modbase.
brandria
Post by brandria »
Alright thanks for the answer, I will try that when I come back to my home !
brandria
Post by brandria »
Just reinstall everything waiting after the install but still does not work :(
