f4-210 frequent unscheduled shutdown/restart
Re: f4-210 frequent unscheduled shutdown/restart
{L_BUTTON_AT}ianbhenderson73
The power control board of your TNAS may be failed, please email to the service team for warranty service.
sianderson
Post by sianderson »
ianbhenderson73 wrote: 12 Sep 2021, 05:07 At present the unit is configured to shut itself down at 4am every day, and reawaken at 4:05am.
im curious why do you feel the need to turn it off for 5 minutes at 4am? for what purpose are you shutting it down and powering it back up 5 minutes later?
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Hardfecx
Post by Hardfecx »
sianderson wrote: 14 Sep 2021, 21:56 im curious why do you feel the need to turn it off for 5 minutes at 4am? for what purpose are you shutting it down and powering it back up 5 minutes later?
mee too, it's nonsense
ianbhenderson73
Post by ianbhenderson73 »
My thinking is that by doing that, it clears down the memory.
To explain, my IT background is with Microsoft Windows which is notoriously bad for memory leakage and poor garbage collection. If that approach isn’t necessary then I’ll disable it.
titanrx8
Post by titanrx8 »
ianbhenderson73 wrote: 15 Sep 2021, 04:41
If you have apps that do things like re-inspect or re-org a database everytime you boot up, you are introducting load and disk activity which might slow down other processes and add to disk wear. I do scheduled shut downs for 7 hours and on bootup a couple of apps take over 100% of cpu for 20-30 minutes. Without rebooting, the apps would only run those routines once per week.
sianderson
ianbhenderson73 wrote: 15 Sep 2021, 04:41 My thinking is that by doing that, it clears down the memory.
i personally just leave mine running (as thats what they are designed for), it seems to maintain its ram level etc without any problems, in the past there have been memory leaks but TM have released fixes for them quite quickly, the latest version for me is stable
i'm just thinking you are perhaps adding extra pressure on the nas drive and hard drives by having it shut down and boot up all the time, and then perhaps consider a weekly or monthly shutdown, but daily seems overkill
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
ianbhenderson73
sianderson wrote: 15 Sep 2021, 18:21
It seems that Terramaster have diagnosed it as a fault with the power switch. I suspect that my unit has been part of a bad manufacturing run because a colleague of mine bought the same unit on the same day from the same source.
Terramaster have been in touch to arrange a swap for a new unit. Once that unit is available, I’ll perhaps look at scheduling the unit to automatically restart occasionally - your suggestion of once a month sounds like the winner there.
