Unable to copy dot files from external source, using smb
parveen7ghjsingh
Re: Unable to copy dot files from external source, using smb
Post by parveen7ghjsingh »
The problem got resolved by activating the option show hidden files in Nexctloud WebUI in Settings for External Storage.
V8Triker
Post by V8Triker »
My original post has nothing to do with Nextcloud.
The issue is that the .dot files are not visible in TNAS.
I can see the .dot files on the Ubuntu source.
I have also stated that with persistence, you can see them in TNAS.
However, the root issue is that any copy/create/rsync fails as the creation of the destination object can not be confirmed.
This example could not be any clearer in showing the issue:
V8Triker wrote: 01 Sep 2021, 20:06 ....... Even trying to create the file from a mount point, on the Ubuntu server, does not work if the file name starts with a dot.
root@bubble:/media/tnas/ServerFolders/test# echo 'The test of nothing' >._ demo.txt
-bash: ._: No such file or directory
root@bubble:/media/tnas/ServerFolders/test# echo 'The test of nothing' >demo.txt
root@bubble:/media/tnas/ServerFolders/test# ls
 demo.txt   dir1  'Test document.txt'
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
Return to “File Services”
