Access other network shares within TOS
Re: Access other network shares within TOS
Also, I cannot access the drives. The user account admin no longer appears to work. I cannot get to my data at this time either.
I used the tactic of pulling out all the drives, installing one and doing a full reinstall of TOS that way.
Once I was back into the OS, I popped the other three drives back in. Rebooted. File check was done (this time it didn't crash out with that error).
I appear to be 100% online and functional now.
I'll go back to my original mounting quest.
TMnorah
Hello, you can refer to the following method to reinstall:
viewtopic.php?f=75&t=423
Please select a suitable TOS system for installation according to initboot:
viewtopic.php?f=75&t=921
Hope to help you!
Hope to help you!
Good job!
In TOS Control Panel, the option to mount the remote media folders (those held in your other NAS/pc) should now be available (assuming you have upgraded to a version which has the option). If so, go ahead
You could then add the mounted remote folder as a media source to your Plex Media Server running inside TOS.
(This is what I meant by "Similarly, you should be able to add your media in the other NAS/network shares to your TOS-hosted Plex Media Server" in my first reply)
F2-221
Weird. After setting that up, and setting up Plex. I got the "four red lights of death" on my NAS. I had to jerk the drives out and do the install again.
Very strange. I may abort the Plex plans. I can't have the NAS down.
Hi! Do you mean that the TNAS can be used normally before the plex is set up, and the hard drive lights all turn red after setting up? Then after stopping the plex, TNAS can be used normally again? Perhaps you can describe your problem in detail. By the way, which TOS version do you use currently?
