[ SurveillanceMotion ] Surveillance software
Spider
Re: [ SurveillanceMotion ][ 1.01.00 ] Surveillance software
Post by Spider »
Oh ok thank you for that info.
Do you know if that works with Ubiquiti cams?
Spider
Post by Spider »
Ok thank you
Re: [ SurveillanceMotion ] Surveillance software
added TOS5 version
brunix86
Italy
Post by brunix86 »
outkastm wrote: ↑30 Jan 2023, 17:45 added TOS5 version
Hi, could you gently add also TOS4 version?
Thanks! ;)
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1536 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
brunix86
Italy
Post by brunix86 »
brunix86 wrote: ↑30 Jan 2023, 17:57
Thanks! ;)
Hi, could you insert also TOS4 version?
I remember that some time ago it was available here, but on "tmnascommunity.eu" portal isn't available anymore.
Thanks and Regards!
My NAS Environment
  • TNAS F4-424
maaeel
Post by maaeel »
Is there any option to compile ARM version of this packageor is this too complicated (pre-reqs!) / arm code does not exist?
Sorry, too much to compile and i have no arm device to test it
Jhac
Portugal
Post by Jhac »
Thank you for your efforts. I'm not being able to run the app although I believe I installed everything requested. I do have Phyton 3, mod and ffmpeg.
The error I'm getting. Any help?
/usr/local/SurveillanceMotion/functions/dependapps.sh: line 77: [: too many arguments
Will use Volume1
/Volume1/DockerData
/Volume1/DockerData/btrfs to store config files
The main volume is /Volume1
chown: cannot dereference '/usr/local/SurveillanceMotion/sys/lib/galera/libgalera_smm.so': No such file or directory
chown: cannot dereference '/usr/local/SurveillanceMotion/sys/venv/bin/python': No such file or directory
chown: cannot dereference '/usr/local/SurveillanceMotion/sys/venv/bin/python3': No such file or directory
chown: cannot dereference '/usr/local/SurveillanceMotion/sys/venv/bin/python3.10': No such file or directory
/bin/bash: /Volume1/@apps/SurveillanceMotion/sys/venv/bin/meyectl: /usr/local/SurveillanceMotion/sys/venv/bin/python: bad interpreter: No such file or directory
/bin/bash: line 1: /Volume1/@apps/SurveillanceMotion/sys/venv/bin/meyectl: Success
Wait for a new app release to be compatible with latest TOS5.1
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}outkastm
Hi, from latest TOS version 5.1.123, TerraMaster maybe changed some system files and now SurveillanceMotion won't start anymore. This is the Start.log content:
Will use Volume1
/Volume1/@DockerData
/Volume1/@DockerData/btrfs to store config files
Note that until previous version 5.1.103 it worked fine. I tried to reinstall the TPK but the issue still occurs. Could you kindly check what's wrong with this package? Thanks
My NAS Environment
  • TNAS F4-424
