[ AdGuardHome ] Network-wide software for blocking ads & tracking
Nodsert
Re: [ AdGuardHome ][ 0.107.6.0 ] Network-wide software for blocking ads & tracking
Post by Nodsert »
outkastm wrote: ↑02 May 2022, 07:28 use a tool to generate a new Bcrypt hash, you can use Bcrypt hash
Edit the config file and replace the existing hash on the password line with the new generated hash
The configuration file does not display the content and is not editable.
PriestyUK
Post by PriestyUK »
[at=outkastm post_id=9832 time=1618343292 user_id=2797][/at]
Since reading this and looking into it, I would really love to get home assitant working on my NAS, i've tried using the docker container for this but i'm not getting very far, think I need some assitance :(
Unfortunately i don't use docker and can't help with that.
I can produce a tpk file for HA Core, see the limitations on the table.
PriestyUK
Post by PriestyUK »
AdGuard Home v0.107.7 is now available :o
PriestyUK
Re: [ AdGuardHome ][ 0.107.7.0 ] Network-wide software for blocking ads & tracking
Post by PriestyUK »
This update has done something weird to my other installed applications. I cant see them in the installed section and they fail to load, if I reinstall them they work again, also it must still be running as it is forceing DNS settings but not allowing internet access. How do I manually delete/remove this to get things running again?
PriestyUK
Post by PriestyUK »
Sorry the last application I installed was HomeAssistant
Have you tried to reboot the NAS? I will check this later tonight but I didn't had any issues during HA installation.
