Bump.
Can anyone from Terra-Master comment on whether or not it's true PWM implementation?
What controls fan speed?
Re: What controls fan speed?
Currently, the fan control from TerraMaster is not compatible with PWM, and shortly we don't have plan to modify current design.
Thanks Roy!
Just to confirm, do you mean it's not compatible because:
a) Terra-Master has taken the PWM standard and re-arranged the pins with a non-PWM connector, or;
b) The fans in Terra-Master NASs are not using a PWM signal to control the speed.
